Re: spark plugs for a street 360
[Re: None2Slow]
#2767018
04/22/20 08:58 AM
04/22/20 08:58 AM
Posts: 1,758 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Great experience with the NGK BKR5E-11 or BKR6E-11 (difference being the heat range). This is a V-grove plug, I've attached the spec sheet for both the plugs as well as the NGK plug naming chart.
Oh, in my case, I went from the hotter to the colder plug as I moved from a 9.5:1 to 10.5:1 static CR on my 360 motor.
[Re: Cab_Burge]
#2767063
04/22/20 11:39 AM
04/22/20 11:39 AM
Posts: 4,457 Washington
madscientist
Washington
Champion RN9YC(also RC9YCwill work) or maybe, if you can find them ,one step hotter RN10YCand RC10YC or Autolite #3924 or 3925, those two Autolite plugs have the 5/8 inch hex on them but they will work fine in your motor. I can't remember the proper part # for the standard Autolite 3/4 inch reach resistor spark plugs with the standard 13/16 hex on them That’s too cold for a 10:1 pump gas deal. A champion RC12YC would be the coldest for that and most likely it will need a RC14YC.
[Re: madscientist]
#2767067
04/22/20 11:44 AM
04/22/20 11:44 AM
RapidRobert
NGK has a good rep. I'd say stock heat range or maybe 1 colder & go from there
[Re: mopar dave]
#2767133
04/22/20 02:54 PM
04/22/20 02:54 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
A 3rd recommendation for RC12YC or equivalent other brand.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: qwkmopardan]
#2768155
04/25/20 03:19 PM
04/25/20 03:19 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Autolite 65 would be a stock heat range, stock configuration (13/16, extended tip, 3/4 reach) plug. Go to 64 or 63 to go colder. This crosses to a BPR5ES NGK. Those are the only brands I would consider. The 5/8 hex is an Autolite 3924 which goes to a BCP5ES if my memory is correct. Champion?
[Re: None2Slow]
#2768255
04/25/20 08:22 PM
04/25/20 08:22 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I should have ask first if this is a iron head motor or aluminum head motor? If iron colder like I recommended originally is way safer than to hot
[Re: None2Slow]
#2768271
04/25/20 09:25 PM
04/25/20 09:25 PM
Dave_J
Auburn WA
Iron stock. RN12YC or equivalent.
[Re: Dave_J]
#2768318
04/26/20 03:05 AM
04/26/20 03:05 AM
Cab_Burge
The 1968 to 1971 340 motors came with N9Y plugs originally They are not available any more I've been told so the closest one to them is the RN9YC resistor plug and then the resistor 5/8 body RC9YC in the Champion line. I had a 8.5 to 1 compression 350 Chevy iron head motor in a 21 ft. inboard outboard ocean boat that would ping with the stock RJ12Y plugs in it and wouldn't ping with a R11Y plug in it He is at 10.+ to 1 compression ratio so I'm thinking a #10 or #9 champion should be just about right at his altitude
[Re: Cab_Burge]
#2768348
04/26/20 09:29 AM
04/26/20 09:29 AM
madscientist
Washington
The 1968 to 1971 340 motors came with N9Y plugs originally They are not available any more I've been told so the closest one to them is the RN9YC resistor plug and then the resistor 5/8 body RC9YC in the Champion line. I had a 8.5 to 1 compression 350 Chevy iron head motor in a 21 ft.inboard out board ocean boat that would ping with the stock RJ12Y plugs in it and wouldn't ping with a R11Y plug in it H e is at 10.+ to 1 compression ratio so I'm thinking a #10 or #9 champion should be just about right at his altitude Cab, if you look up what Champion calls out in a newer catalog you’ll see it says a 12 heat range for that stuff. I can’t remember what year that changed, but IIRC there was an industry wide change in pump fuel blending (I think it was before OBDII but I wouldn’t swear to that in court), probably because of a federal regulation (wouldn’t swear to that in court either but that’s kinda what I remember) that required a heat range change.
[Re: madscientist]
#2768354
04/26/20 09:44 AM
04/26/20 09:44 AM
Posts: 1,977 Apollo, PA.
B1MAXX
Apollo, PA.
The 1968 to 1971 340 motors came with N9Y plugs originally They are not available any more I've been told so the closest one to them is the RN9YC resistor plug and then the resistor 5/8 body RC9YC in the Champion line. I had a 8.5 to 1 compression 350 Chevy iron head motor in a 21 ft.inboard out board ocean boat that would ping with the stock RJ12Y plugs in it and wouldn't ping with a R11Y plug in it H e is at 10.+ to 1 compression ratio so I'm thinking a #10 or #9 champion should be just about right at his altitude Cab, if you look up what Champion calls out in a newer catalog you’ll see it says a 12 heat range for that stuff. I can’t remember what year that changed, but IIRC there was an industry wide change in pump fuel blending (I think it was before OBDII but I wouldn’t swear to that in court), probably because of a federal regulation (wouldn’t swear to that in court either but that’s kinda what I remember) that required a heat range change. I think they have upped the heat range on the older engine listings because they assume they are old and need it to keep them clean from deposits of a high mileage engine.
[Re: B1MAXX]
#2768454
04/26/20 04:33 PM
04/26/20 04:33 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We ran 55 Autolites in our iron head race deal for years. It used to be you just had to have cold plugs. But every time I stepped it up, the thing sounded happier. So that's what it got. Went to 3924s. Same basic construction & heat with a 5/8" hex.
