Which trans to use? 800-1000HP #2766223
04/20/20 09:46 AM
04/20/20 09:46 AM
Fort Collins, Colorado
CoDart Offline OP
CoDart  Offline OP
Hi guys I am in the mix of getting a fully forged BGE 6.4 together to replace the 440 that is in my Dart. My goal is to get it running NA and then once that is sorted out I want to fab up a turbo kit for it. Right now I am torn on that transmission to use as I eventually want to be in the 800-1000hp range once the chassis is sorted out. I want it to be reliable and streetable. It will be 50/50, race/street. I have a powerglide,th400 and 727 in the garage. Which one would you guys choose and why? Thanks!
Re: Which trans to use? 800-1000HP [Re: CoDart] #2766558
04/21/20 02:55 AM
04/21/20 02:55 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I'd sell those other turds and get a 545rfe. twocents
The rfe is bullet-proof, doesn't have as much power loss as a 727, and are plentiful/cheap to aquire.
Mo' Farts
Moderated by "tbagger".
Re: Which trans to use? 800-1000HP [Re: Grizzly] #2766690
04/21/20 12:26 PM
04/21/20 12:26 PM
IL
furious70 Offline
furious70  Offline
IL
there's a couple Paramount NAG1's for sale on the LX forums right now that are their 800-1000hp set up. Not sure how much street you want since you're considering a glide tho.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Which trans to use? 800-1000HP [Re: CoDart] #2766790
04/21/20 03:40 PM
04/21/20 03:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How heavy is your car?
Re: Which trans to use? 800-1000HP [Re: Clanton] #2766850
04/21/20 06:49 PM
04/21/20 06:49 PM
CoDart Offline OP
CoDart  Offline OP
The car weights 3450lb with a tunnel ram iron head 440 in it now and with me(230lb) in it.
Re: Which trans to use? 800-1000HP [Re: CoDart] #2766937
04/21/20 10:06 PM
04/21/20 10:06 PM
SC304 Offline
SC304  Offline
Personally I run naturally aspirated gen 3 powered challengers at 3400 lbs with Beefed up 727’s.
ET’s are 9.0s with a Transbrake.
These are not street driven tho.
I just asked this same question of my transguy. If I put a blower motor in my car, can I use my proflite trans or the turbo 400s and add a brake.
He responded turbo 400, Less service required, more readily available components as well for the 400.
