Re: E-Body Rallye gauge question???
[Re: aar1]
#276680
04/04/09 02:21 PM
04/04/09 02:21 PM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
The short answer is 'yes'. The clock reset knob is actually attached to a cable that runs to the back of the clock. The cable is now available in reproduction through BE/A Parts and other suppliers. The stem for the odometer reset is also available - JulesdaWiperman had a batch of them made up, you may also want to try Greg at http://www.rt-eng.comThe knobs themselves and the special barrel nuts to hold them are available from a variety of sources for about $50/pr
[Re: aar1]
#276682
04/04/09 03:45 PM
04/04/09 03:45 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
I have a set of 70-71 E-Body Rallye gauges that have a problem. At some point in the cars life, some idiot couldn’t figure out how to remove the knobs from the 2 reset stems so they just used some pinchers to snip the stems off. They are basically cut flush or actually a bit below the face of the woodgrain. Is there a way to repair this? Can those reset stems be replaced without a whole lot of trouble? The gauges are currently not in the car so access isn’t an issue. Thoughts appreciated.
We are in the process of another production run on the reset cables. We also made the knobs w/barrel nuts.
[Re: HEMICUDA]
#276683
04/04/09 06:08 PM
04/04/09 06:08 PM
Posts: 788 middle of the country
aar1
Thanks Mike, I may be hitting you up for another clock cable. Do you have any insight about replacing the trip odo reset stem? Sounds like that will be the only real problem in replacing both stems, since the other one is part of the clock cable.
[Re: aar1]
#276684
04/05/09 03:52 AM
04/05/09 03:52 AM
HEMICUDA
Medina, Ohio
That's a problem, I would call Mike Mancini (508-932-1349) and see what he says.
