Re: 71 RR 340 Six Barrel Conversion W/Air Grabber
[Re: 72 RR DUDE]
#2766802
04/21/20 04:10 PM
04/21/20 04:10 PM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
Yes you can get in trouble. The air cleaner base on a 340-440 are the same 2" high. The base on a 383-400 are 2 1/2 high. If you use the 2 1/2 it will break the bubble!!! I would agree that he should check the air cleaner base height, but he talking about a 340 Six Barrel conversion. The factory never made a 383-400 Six Barrel air cleaner base plate so the different height of a low deck big block base plate isn't a problem in his case.
[Re: 72 RR DUDE]
#2767520
04/23/20 05:10 PM
04/23/20 05:10 PM
Posts: 380 Mesa, Az
GETX
Mesa, Az
Sorry for any mixup. The single carb air cleaners are the ones that are different the six pack are the same! No problem at all. I was a little lost in this case as I have never been involved with a small block six barrel set-up going in an air grabber car. Thanks for all the help !!
