Re: Where is IFR in this metering block
[Re: varunner]
#2766172
04/20/20 01:28 AM
04/20/20 01:28 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
When you say IFR are you wanting the idle fuel feed restrictors or intermediate, transition, fuel feed restrictors?
[Re: lewtot184]
#2766421
04/20/20 05:53 PM
04/20/20 05:53 PM
Posts: 661 Virginia
varunner
Virginia
Yes it is. thanks I'll have a look. So I've tried tried putting wire in the idle bleeds. The original bleed size is .066" I used .014, .018, .030 wires. I gained about 50 rpm in gear, but did not really see much of a change. Vacuum is around 12 in. idleing. Mixture screws were 1.5-2 turns. Throttle plates all are drilled .120 and transfer slot closed up nicely, open about .030" I may try putting the timing at 20, 25 to see if it helps. Locked at 37 now. is this a factory mopar holley? if so the idle jet is probably a tube in the main well and can be seen by removing the jets. and, if i'm correct they are very lean and reducing the idle air bleed helps.
[Re: lewtot184]
#2766424
04/20/20 06:05 PM
04/20/20 06:05 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
is this a factory mopar holley? if so the idle jet is probably a tube in the main well and can be seen by removing the jets. and, if i'm correct they are very lean and reducing the idle air bleed helps. It is. We can see it in the photos in the linked threads. There's a photo with the jets removed. 50 rpm less drop in rpm is progress. .066 IAB = .00342 in sq .030 wire = .00071 in sq Equivalent of .059 IAB You could try larger. .035 wire would be equivalent of .056 However it is looking like what will be needed is larger IFRs. I think the engine will like a little less timing at idle, but very well may need even larger IFRs then. I've not removed the tubes from blocks, but several guys on RFS have. Besides Tuner, Deeproots, Hank, Mike all have with varying luck in not damaging them in the process. So its definately possible. I can try to put you in touch with one of them if you want. Mark who posted earlier in this thread, and Dom (Thumperdart) may have experience removing them also. if you're allowed to change metering blocks, that might be the easiest solution, assuming all of the circuit connections line up.
[Re: varunner]
#2766490
04/20/20 09:15 PM
04/20/20 09:15 PM
Posts: 304 Florida
Mark Whitener
I would check and see if they will allow a replacement cast block be used, a Holley 11180 block will allow you to put adjustable lower idle feeds in.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: varunner]
#2766611
04/21/20 09:15 AM
04/21/20 09:15 AM
Posts: 3,916 usa
lewtot184
usa
Great info. I like the idea of going thru the bottom of the metering block. I will give it a shot. I could probably just change the metering block, but modifying the original will be much more fun i was looking on line sometime back and found some aluminum plugs for carb holes, believe it was Mikes Carbs, if you don't want to do the set screws. set screws will need to be sealed. I've found that playing with the air bleeds can help some but in the end it's fuel volume you need and the only way to increase it is bigger idle jets. I really go after idle jets anymore for lower rpm.
[Re: lewtot184]
#2766620
04/21/20 09:27 AM
04/21/20 09:27 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Throttle plates all are drilled .120 Unless the rules have changed, you aren’t allowed to drill the secondary blades. I also don’t recommend “asking” if you could use different metering blocks.
[Re: varunner]
#2766658
04/21/20 11:13 AM
04/21/20 11:13 AM
Mattax
Phila. Pa.
Opening the hot idle comp is a great idea for WOT, but would hurt me with trying to richen the idle. I'll have to save that idea for later. I'll update this after I do some adjusting. Actually I don't understand how this would help at WOT. It's just a small air passage. Yes? At idle, consuming 4 to 6 cfm, or maybe 8-10 with a high idle rpm, the compensator will flow a small but noticible percentage of that. At mid to high rpm, WOT, its going to be a tiny fraction of a percent. (It's not like a bleed into the circuit which alters the pressure difference and the density.) Here's some of Mike's tips on removing those tubes without damage. https://www.tapatalk.com/groups/rac...signs-and-assuming-not-t1793.html#p17512That might be easier than drilling from the bottom unless you have a cross vise on a milling machine or drill press and can index the well accurately???
[Re: Mattax]
#2766776
04/21/20 02:59 PM
04/21/20 02:59 PM
Posts: 661 Virginia
varunner
Virginia
It's a pretty good size passage, I might try it sometime. So I accessed the idle jet from the bottom of the metering block. It is indeed .022" I opened it up to .033" I've JB welded the set screws and will give it overnight to cure before it start it up again. Thanks again guys for all the tips. Opening the hot idle comp is a great idea for WOT, but would hurt me with trying to richen the idle. I'll have to save that idea for later. I'll update this after I do some adjusting. Actually I don't understand how this would help at WOT. It's just a small air passage. Yes? I At idle, consuming 4 to 6 cfm, or maybe 8-10 with a high idle rpm, the compensator will flow a small but noticible percentage of that. At mid to high rpm, WOT, its going to be a tiny fraction of a percent. (It's not like a bleed into the circuit which alters the pressure difference and the density.) Here's some of Mike's tips on removing those tubes without damage. https://www.tapatalk.com/groups/rac...signs-and-assuming-not-t1793.html#p17512That might be easier than drilling from the bottom unless you have a cross vise on a milling machine or drill press and can index the well accurately???
[Re: lewtot184]
#2766782
04/21/20 03:09 PM
04/21/20 03:09 PM
fast68plymouth
So. Burlington, Vt.
another thing that can help the situation is to open up the idle feed restriction in the secondary metering plate. the old bulletins say to open this up to .070"; that's a bunch considering it's probably .036". I would try this to help compensate for the primary side but I don't think i'd jump to .070" if I was doing the primary side mods. going to .40"-.045" would make a noticeable difference in area. If you clicked on the first link Mattax posted there are some good pics of the baseplate. I don’t know if all of this list number carb were the same as that one, but that carb had no actual secondary “idle” circuit. There were only some slots/feed holes positioned well above the throttle blades....... so they contributed no additional fuel at idle....... so making the feed restrictions for that circuit bigger shouldn’t have any impact on the idle a/f ratio. In one of the other links where another person was playing with one of these carbs, they also referred to the lack of that circuit, which is also used to keep the fuel in the secondary bowl refreshed.
[Re: varunner]
#2766794
04/21/20 03:49 PM
04/21/20 03:49 PM
Posts: 3,916 usa
lewtot184
usa
It's a pretty good size passage, I might try it sometime. So I accessed the idle jet from the bottom of the metering block. It is indeed .022" I opened it up to .033" I've JB welded the set screws and will give it overnight to cure before it start it up again. Thanks again guys for all the tips. Opening the hot idle comp is a great idea for WOT, but would hurt me with trying to richen the idle. I'll have to save that idea for later. I'll update this after I do some adjusting. Actually I don't understand how this would help at WOT. It's just a small air passage. Yes? I At idle, consuming 4 to 6 cfm, or maybe 8-10 with a high idle rpm, the compensator will flow a small but noticible percentage of that. At mid to high rpm, WOT, its going to be a tiny fraction of a percent. (It's not like a bleed into the circuit which alters the pressure difference and the density.) Here's some of Mike's tips on removing those tubes without damage. https://www.tapatalk.com/groups/rac...signs-and-assuming-not-t1793.html#p17512That might be easier than drilling from the bottom unless you have a cross vise on a milling machine or drill press and can index the well accurately??? don't be afraid to play with reducing the idle air bleed i.d.
[Re: fast68plymouth]
#2766795
04/21/20 03:51 PM
04/21/20 03:51 PM
Posts: 3,916 usa
lewtot184
usa
another thing that can help the situation is to open up the idle feed restriction in the secondary metering plate. the old bulletins say to open this up to .070"; that's a bunch considering it's probably .036". I would try this to help compensate for the primary side but I don't think i'd jump to .070" if I was doing the primary side mods. going to .40"-.045" would make a noticeable difference in area. If you clicked on the first link Mattax posted there are some good pics of the baseplate. I don’t know if all of this list number carb were the same as that one, but that carb had no actual secondary “idle” circuit. There were only some slots/feed holes positioned well above the throttle blades....... so they contributed no additional fuel at idle....... so making the feed restrictions for that circuit bigger shouldn’t have any impact on the idle a/f ratio. In one of the other links where another person was playing with one of these carbs, they also referred to the lack of that circuit, which is also used to keep the fuel in the secondary bowl refreshed. I based my comments on a 1971 race bulletin carb mods. maybe the bulletin and me are off base,....lol.
[Re: varunner]
#2766920
04/21/20 09:33 PM
04/21/20 09:33 PM
Mattax
Phila. Pa.
I guess I would have used a fuel resistant pipe thread sealant. .033 is a good starting point. Maybe a littlke larger than I would jchanged to in the first test but that's OK. That should give you room to drop the idle timing. Even if it means 10"Hg manifold vac, the restriction is less it may all work out. As far as IAB and IFR. They do pair together. If you find the fueling is too rich off idle, or it needs a little trimming at idle, open the IAB up. Don't forget you can also get some adjustment on the idle fuel ratio by changing the transfer slot exposure slightly. So take the time to try different combos before drilling again.
