Big block stroker, please post your low rpm torque! #2765394
04/18/20 10:11 AM
04/18/20 10:11 AM
gregsdart Offline OP
To learn a bit more about head choices for 493 to 540 STREET strokers, please post
1cubic inch
2head used
3Dyno torque down low, preferably from 2500 to 4000?
4work done on heads, compression ratio
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2765410
04/18/20 10:35 AM
04/18/20 10:35 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Going to be difficult to get correct numbers if they are chassis dyno numbers with a good converter. Not a whole lot of engine dyno runs are correctly logged from 2500 either.
Curious what shows up here though...
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2765412
04/18/20 10:38 AM
04/18/20 10:38 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Greg I can't give you a dyno number but can give an et.
1) 512
2) Edelbrock Performer
3) 7.02 in the 1/8 shift at 5500 in a 4150lb car
4)better valve job and minor bowl clean up, 11.5 comp
Ok
Re: Big block stroker, please post your low rpm torque! [Re: cudatom] #2765458
04/18/20 11:50 AM
04/18/20 11:50 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
9:1 493 RB
OOTB RPM with a good valve job
MP509 1.7 rockers
M1 single plane TBI
500 ft/lbs from 2000 on. 600ft/lbs @ 4000 peak.
Kevin
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2765465
04/18/20 12:09 PM
04/18/20 12:09 PM
Sweden
Cuda_70 Online content
Cuda_70  Online Content
Sweden
1 558 cui
2 Trick Flow 270
3 3500-4000-4500 rpm => 599-735-789 ft/lbs
4 Port matched to the intake and the 4.5 bore, 11,1 comp
Re: Big block stroker, please post your low rpm torque! [Re: Cuda_70] #2765476
04/18/20 12:44 PM
04/18/20 12:44 PM
UK
rb446 Offline
rb446  Offline
UK
A bit larger than asked for but>
1. 589ci.....
2. Indy -13 CNC365's
3. @3800-685ftlbs - 4000/706 - 720ftlbs@4400
4. 10:1CR
Indy 440-2/.625/.625" S/roller 260/270@.050, 110.....950HP carb.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Big block stroker, please post your low rpm torque! [Re: TRENDZ] #2765479
04/18/20 12:45 PM
04/18/20 12:45 PM
I agree it will be tough. But hopefully there will be enough info for making choices to fit various budgets and goals.
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2765504
04/18/20 02:04 PM
04/18/20 02:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Outside your parameters but our 655 made 960ft/lbs at 5500..
Re: Big block stroker, please post your low rpm torque! [Re: Al_Alguire] #2765513
04/18/20 02:26 PM
04/18/20 02:26 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
505, 10:1, RPM heads with valve job and bowl blend, original Torker, 850vs, 1-7/8” headers, small HFT cam.
Started pull at 3200........ 592ft/lbs.
Peak tq @4000....... 628ft/lbs.
Most of the stuff is run with an auto trans, and there isn’t much point in pulling the motor way down below what the converter would stall at........ so it’s pretty rare I’d pull one down to 3000 or lower.
Re: Big block stroker, please post your low rpm torque! [Re: fast68plymouth] #2765519
04/18/20 02:38 PM
04/18/20 02:38 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
498 rb stroker
Comp ratio is 10,5 and runs great with europe 95 octane pump gas
Edelbrock rpm slightly ported valve seat work from out of the box
Cam flat tapper hydralic dur @.050 242 246
On rear tires at 2800 rpm 650nm and 3900 rpm 714nm on a 4 speed trans.
Re: Big block stroker, please post your low rpm torque! [Re: Mopar Guy] #2765610
04/18/20 06:55 PM
04/18/20 06:55 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Don't have low rpm numbers but 505 ci, OOTB Trick Flow 270 heads with 337 intake, 11.1:1 compression made peak 709 ft lbs at 4600 rpm.........
Re: Big block stroker, please post your low rpm torque! [Re: markz528] #2766178
04/20/20 03:00 AM
04/20/20 03:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My 493 with a 440Source 4.15 stroker kit
Indy EZ heads
10.6 comp
Good quench as I drive and race it on 92 pump
Never dyno'd but has run a best of 10.76 @ 125 in my 63 Sport Fury that's 3700 lbs without me. Ron
Re: Big block stroker, please post your low rpm torque! [Re: 383man] #2766242
04/20/20 11:11 AM
04/20/20 11:11 AM
UK
rb446 Offline
rb446  Offline
UK
Indy EZ heads
10.6 comp
616fwhp up
Re: Big block stroker, please post your low rpm torque! [Re: rb446] #2766280
04/20/20 12:15 PM
04/20/20 12:15 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
572"
15:1
-1 heads
749 @ 5400
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2766281
04/20/20 12:20 PM
04/20/20 12:20 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
1cubic inch
2head used
I see the big inch engines posted so here is one a little smaller .
470 cu
Edelbrock RPM heads . Port matched to RPM intake some minor port work and a comp valve job. 10.72 to one good quench.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Big block stroker, please post your low rpm torque! [Re: Hemi Allstate] #2766395
04/20/20 05:22 PM
04/20/20 05:22 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
No idea on the torque, but 770hp works well enough to carry the front wheels on my little 512/400 from 440source!
1.31 60ft
https://www.youtube.com/watch?v=j7piYsuPYe8&t=54s
Re: Big block stroker, please post your low rpm torque! [Re: Hemi Allstate] #2766423
04/20/20 06:03 PM
04/20/20 06:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
No dyno#s
512 ci, 4100lb 68 Charger , street car trim 3.54 gear 11.04 @ 123 so far.
Re: Big block stroker, please post your low rpm torque! [Re: CSK] #2766466
04/20/20 08:22 PM
04/20/20 08:22 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2766506
04/20/20 09:54 PM
04/20/20 09:54 PM
I don't have the dyno sheets anymore, they went with the car, my first pump gas 511 C.I.400 block stroker motor with a set of 906 iron heads with 2.14 intake and 1.81 exhaust valves and mild porting, they flowed 266 CFM at .700 valve opening on a S/F 600 bench. It had 9.25 to 1 compression ration and low deck eddy six pack dual plane intake with 440 six pack carbs, it made over 400 Ft lb. at 2500 RPM and over 500 Ft' lb, at 3100 RPM and then went over 600 Ft lbs. from there until it made peak torque at 4500 RPM at 644 Ft. Lb. Peak HP was 612 HP at 5500 RPM but that stupid motpr would run faster shifting it at or above 7000 RPM shruggy.
I have notice on the pump gas motors I dyno tested, stock stroke or strokers, that had less than 10.5 to 1 compression that hey would make more torque than HP, once the compression goes above that they make more HP than torque confused
I'll look in the shop tomorrow morning and see if I can find some more recent dyno sheets luck
Re: Big block stroker, please post your low rpm torque! [Re: Cab_Burge] #2766780
04/21/20 03:03 PM
04/21/20 03:03 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
My Mega 496 has 12.5 compression, I know a little steep. But w/Bullet custom hydraulic cam & Performer RPM heads, dual plane Performer RPM intake & only a 750dbl pumper made 581hp @ 5400 624tq @ 4300
Sorry cheated, used this on 2 posts
Ken
