Re: Best big block heads for a 500 cid
[Re: 440Jim]
#2765390
04/18/20 10:05 AM
04/18/20 10:05 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I will get this started and suggest using the Moparts.com search feature and look at Trick Flow heads, TF240, TF270, The customers desired results are important, torque converter stall speed, gears, car weight, etc. I am going to start a new thread on low rpm stroker torque to help answer this question.
[Re: fastmark]
#2765466
04/18/20 12:09 PM
04/18/20 12:09 PM
Posts: 31,076 Oregon
AndyF
What do you mean by best? Is this going to be a race engine or a street engine? You said street engine but you posted the thread in the race section so you're going to get answers that are all over the place.
[Re: AndyF]
#2765518
04/18/20 02:36 PM
04/18/20 02:36 PM
fast68plymouth
So. Burlington, Vt.
Seems like the no brainer slam dunk hot “street” head....... for a car that’s more street than race would be the TF240.
If the emphasis is more on “making power”, then it’s time to start thinking MW sized ports....... understanding that using parts to exploit the MW sized ports are going to somewhat compromise the street manners.
A lot of it just comes down to what you’re trying to build. A street friendly pump gas stroker making 640tq/550hp can easily be done with some cleaned up E Streets and a nice cam.
If you’re trying to make solidly over 600hp, then it’s just easier with better heads.
[Re: fastmark]
#2765834
04/19/20 10:13 AM
04/19/20 10:13 AM
fast68plymouth
So. Burlington, Vt.
The TF’s are cnc ported....... and IMO are going to be fine as is for 95% of the people looking to build motors where the bulk of use will be driving down the road.
Being used with pump gas CR’s, and a power brake friendly cam...... the heads aren’t likely going to be the main limiting factor for how much power is being made.
[Re: fast68plymouth]
#2766035
04/19/20 05:30 PM
04/19/20 05:30 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) . Source CNC or TF240 . If it is A12 clone inc 6 pack . If more power required Tf270 . Then choice is stock look head or not . Don't forget not all rockers seem to be happy with the TF heads , they recommend a specific brand /model . My Source heads ran fine on my first 505 Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: AndyF]
#2766578
04/21/20 07:51 AM
04/21/20 07:51 AM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
For my own car I'd use TF 240 heads. For a customer car I might go with Edelbrock heads. Can you explain why?
[Re: AndyF]
#2766774
04/21/20 02:51 PM
04/21/20 02:51 PM
Posts: 2,141 junction city oregon
viperblue72
You asked for recommendations for a reasonable priced head that flows better than stock. I don’t see any reason where a Edelbrock is a better idea unless you score a used decent set. An Edelbrock is not ready out of the box. By the time it is ready, you may as well have gotten the CNC ported head that already likely has the springs, locks, and retainers that are needed. Not to mention the casting quality and quality control of Edelbrock has gone to s*^#.
