pistol grip shifter in 83 Ram
#2766014
04/19/20 04:30 PM
04/19/20 04:30 PM
Posts: 3,547 stratford,ontario,canada
JD340
I'd like to add a pistol grip shifter to my 833 OD in my 83 Ram. Which one is the right application. I remember a member put one in his years ago. SandyinNS formerly known as drdodge340 is the guy I remember, but I can't find his old posts on it. Any help guys/gals? Also, any recommendations on a new shifter/rod assembly? Mine's worn and sloppy.
Nothing to see here. Carry on.
Re: pistol grip shifter in 83 Ram
[Re: Moparguy383]
#2766331
04/20/20 02:35 PM
04/20/20 02:35 PM
JD340
I had a '82 Dodge with the 833 OD, I used a '70 B body shifter in it. Worked good for me. After looking at moparmarks picture, I assume you used the console version? Any chance you have a pic of your setup?
[Re: JD340]
#2766373
04/20/20 04:12 PM
04/20/20 04:12 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I did it a little different, whittled a piece of aluminum to take factory grips and threaded it onto the factory stick. '92 D350.
[Re: Moparguy383]
#2766777
04/21/20 03:00 PM
04/21/20 03:00 PM
JD340
John: Very cool! Moparguy383: I'm guessing that put it the grip "right there" up close to the steering wheel, and several inches above the seat. How did you like it?
[Re: John_Kunkel]
#2766878
04/21/20 07:39 PM
04/21/20 07:39 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I did it a little different, whittled a piece of aluminum to take factory grips and threaded it onto the factory stick. '92 D350. You must one hell of a pocket knife there John.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2767116
04/22/20 02:18 PM
04/22/20 02:18 PM
JD340
[Re: moparmarks]
#2767145
04/22/20 03:39 PM
04/22/20 03:39 PM
John_Kunkel
Rio Linda, CA
I did it a little different, whittled a piece of aluminum to take factory grips and threaded it onto the factory stick. '92 D350. You must one hell of a pocket knife there John. My "pocket knife".
