Wiper delay #2765788
04/19/20 09:02 AM
04/19/20 09:02 AM
Western Colorado High Desert
moparmarks Offline OP
The maximum delay on my 98 Dakota is about 3 seconds. The maximum delay on my 97 Dakota, now parts truck, is about 10 seconds and want that in my 98. Which do I change out? Wiper motor, switch or a relay?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Wiper delay [Re: moparmarks] #2765858
04/19/20 10:52 AM
04/19/20 10:52 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Probably the easiest thing to do is just plug the other motor in and run a ground wire to it and see what it does. The motors have a contact plate that can go bad and not let the proper signal be relayed.
Re: Wiper delay [Re: NITROUSN] #2765951
04/19/20 01:33 PM
04/19/20 01:33 PM
moparx Offline
moparx  Offline
bad connections on all the associated electrical components, including grounds, will cause that.
by bad, i mean VERY slightly loose and VERY slightly corroded [not being easily seen] connections. don't forget to look at the relays under the hood.
beer
