Re: 727 band adjustment [Re: mopar dave] #2764312
04/15/20 04:16 PM
04/15/20 04:16 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Just dug out my 727 trans manual from CRT. Forgot I had that. Band adjustment is 2 1/4 turns with 4.2 lever and 2 turns on rear.
Re: 727 band adjustment [Re: mopar dave] #2764414
04/15/20 08:07 PM
04/15/20 08:07 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Sounds perfect to me. It should end up close to that 5/16". If you just snug it with a short wrench you are good.
Re: 727 band adjustment [Re: 4406bbl] #2764426
04/15/20 09:00 PM
04/15/20 09:00 PM
Mt Morris Michigan
Mt Morris Michigan
ok, I will give the 5/16 hex wrench a try for measure. I just drained the fluid and it looked brand new. Thank's for the info guys.
Re: 727 band adjustment [Re: mopar dave] #2765478
04/18/20 12:45 PM
04/18/20 12:45 PM
Mt Morris Michigan
Mt Morris Michigan
Cleanest pan I ever seen. 3/16 gap at the front lever/servo.
Re: 727 band adjustment [Re: mopar dave] #2765536
04/18/20 03:38 PM
04/18/20 03:38 PM
Mt Morris Michigan
Mt Morris Michigan
Set front band to 5/16 gap as instructed from just snug. I had it at 3/16 from snug and it didn’t seem to hurt anything. Rear band was set to spec at 2 turns from 72”#. Ran thru the gears up on stands. All seems well. Thanks guys
