aftermarket b body radiator #2763962
04/14/20 07:02 PM
04/14/20 07:02 PM
taunton, mass. 02780
moparthunder70 Offline OP
What is the best or most reliable aftermarket radiator for a 69 b body 383..(26 inch) so much junk out there...recommendations ?
Re: aftermarket b body radiator [Re: moparthunder70] #2763970
04/14/20 07:30 PM
04/14/20 07:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Glen-Ray is about the best there is if OEM appearance matters.
Re: aftermarket b body radiator [Re: moparthunder70] #2763975
04/14/20 07:35 PM
04/14/20 07:35 PM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hi
do you want stock for restoration or is aluminum ok .
i just got a nice alu one for my 66 hemi some what stock appearing but not a show guy here .
good for a driver / racer type .
look at autocity1958 on e bay ! dont get the black one you can make it black with some hi heat rustolem grill paint !
Re: aftermarket b body radiator [Re: calrobb2000] #2763985
04/14/20 08:16 PM
04/14/20 08:16 PM
GA
roadrunninMark Offline
GA
Re: aftermarket b body radiator [Re: moparthunder70] #2763997
04/14/20 09:08 PM
04/14/20 09:08 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Champion 26" 3 row core. Factory shroud needed a "filler strip" to seal perfectly instead of O.K. Not a factory look but priced right .
Re: aftermarket b body radiator [Re: 67_Satellite] #2764031
04/14/20 11:07 PM
04/14/20 11:07 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
US radiators make a 26" copper brass tripple pass 4 row with a high number of fins that is super nice...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: aftermarket b body radiator [Re: astjp2] #2764038
04/14/20 11:23 PM
04/14/20 11:23 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
ECP works awesome, keeps my 512cid with A/C 180ish all day long. down here in Southeast Texas
Re: aftermarket b body radiator [Re: CSK] #2764088
04/15/20 06:56 AM
04/15/20 06:56 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I've had an ECP in my small block Challenger for two years with no issues.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: aftermarket b body radiator [Re: moparthunder70] #2764127
04/15/20 09:01 AM
04/15/20 09:01 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your asking for the BEST, there's only one choice Glen-Ray, yes it will be "expensive", but quality, fit and finish usually are...
Re: aftermarket b body radiator [Re: moparthunder70] #2764183
04/15/20 11:02 AM
04/15/20 11:02 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Glen Ray, no other choice.
