Page 2 of 3 1 2 3
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763780
04/14/20 10:58 AM
04/14/20 10:58 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Rich,
Thanks for the update, I enjoyed it!
Bill
Re: A little 572 update with ugly pictures [Re: 340Cuda] #2763909
04/14/20 03:59 PM
04/14/20 03:59 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks everyone.
Dave V. convinced me to triple check my lash cap to lock clearance
and gave me an alternative way to verify it using Dykem which was a great tip.
Dave if you see this, thanks again.
I think I just stuck a caliper pin in there last year and it seemed okay at the time.
But that was last year. But this is something to go over maybe more than once, and to be
beyond confident about. I decided to shorten the lash caps a skosh
then use Dave's verification method one more time. "better safe than sorry", triple checked.
So that's what I'm currently picking away at.
Here is the combination of wire parts I assembled for it.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763910
04/14/20 04:00 PM
04/14/20 04:00 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
zippycore
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763912
04/14/20 04:01 PM
04/14/20 04:01 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Wires are the ONLY thing that is slightly easier than a Wedge.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763914
04/14/20 04:03 PM
04/14/20 04:03 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Other side.
I'm going to drill out and use those goofy stock white plastic wire holders, whenever they show up.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763916
04/14/20 04:08 PM
04/14/20 04:08 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I might try this later, just for fun.
Who am I kidding, the whole darn thing is just for fun.
That's why I set myself up with different parts to mess with.
Thanks for reading, any questions just holler.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763922
04/14/20 04:24 PM
04/14/20 04:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
While I don't know a lot about HEMI engines I wouldn't use that one piece valley tray unless you REALLY need to twocents Biggest mistake I made when I built my 493 mad I like your progress so far it should make some nice numbers. I hope it stays cool with your pulley selection because I had almost the same setup for pulleys and mine would run hot after a while of cruising.
Gus beer
64 Plymouth Savoy
Dana 60
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763925
04/14/20 04:31 PM
04/14/20 04:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Say YES to the TUNNEL RAM !!!! smile
Re: A little 572 update with ugly pictures [Re: fourgearsavoy] #2763926
04/14/20 04:33 PM
04/14/20 04:33 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thx for the comment so quick. Will see how it goes.
The Barton and Weiand intake I'm going to mess with have integral valley tray,
which would probably be even worse. The slightly increased difficulty of service is not
really a problem, I am totally used to taking the manifold off for access to the lifter valley.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: CSK] #2763927
04/14/20 04:34 PM
04/14/20 04:34 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
"Oh $#1+ here it comes!!"
(that's what folks say when they see your Charger...maybe this one too someday)
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763959
04/14/20 06:44 PM
04/14/20 06:44 PM
NC
440Jim Offline
440Jim  Offline
NC
Looking at the big Hemi cylinder heads, it reminds me of the years racing my Dart with the 440 based wedge engine.
The BB wedge heads look so small compared to the guys at the track with BB Chevy engines. Those Hemi heads would change that !
Looks good thumbs
Re: A little 572 update with ugly pictures [Re: 440Jim] #2763967
04/14/20 07:07 PM
04/14/20 07:07 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Thanks for taking the time to share so I can live vicariously through your project. wave
Re: A little 572 update with ugly pictures [Re: slantzilla] #2764148
04/15/20 09:32 AM
04/15/20 09:32 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
How well does the indy valley plate line up against the eddie head? - do you have a pic without the intake? And yes that tunnel ram is just calling out "put me on" if you want to sell the tunnel ram let me know
Re: A little 572 update with ugly pictures [Re: DoubleD] #2764263
04/15/20 02:30 PM
04/15/20 02:30 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Looks like it will work as intended, it will need a fairly heavy bead of RTV similar to the AL stock replacement heads
I started mockups with. I want to say it looked like about 3/16" gap but don't hold me to it.
It isn't "captured" by the heads. I can snap a picture later.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: 440Jim] #2764271
04/15/20 02:46 PM
04/15/20 02:46 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Looks good thumbs
Thanks!
Before jumping in, I had to step back and evaluate my past experiences and observations to make sure
I really wanted to do this, and I spent an afternoon mocking up a hemi out of mostly broken parts that
I accumulated back during my time at MP. I rolled the engine stand in front of my car, took pictures and asked myself...."are you sure?" quite a few times. It's as much, or more, for the cool factor and value add as anything.
I'm clearly not a hardcore racer, and I talked myself out of any performance concerns
just adding up 400cfm and 572ci. Hopefully it will make the big torque.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: slantzilla] #2764274
04/15/20 02:52 PM
04/15/20 02:52 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
glad you like it. Still trying to drive some content here in spite of a long list of stuff.
Someone smarter than me suggested a youtube "hemi for regular gearheads" series.
I'm sure there are some who would probably find it useful. I'm not 100% sure I can make it entertaining
enough for those who aren't already in the middle of one, though.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2764300
04/15/20 03:39 PM
04/15/20 03:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rich.. looks good.. I had 1 hemi years ago.. that thing was a PITA.. glad I sold it
wave
Re: A little 572 update with ugly pictures [Re: MR_P_BODY] #2764355
04/15/20 05:55 PM
04/15/20 05:55 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks Mike. Something a little bit different.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2764486
04/16/20 05:09 AM
04/16/20 05:09 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I check all my pulley alignment's with a long piece of 3/8 Ø round stock, i put in in the pulley grove like a v-block and check it to the other rotating pulleys,this method will put you spot on, I don't trust a Visual alignment.
Re: A little 572 update with ugly pictures [Re: RATTRAP] #2764551
04/16/20 10:39 AM
04/16/20 10:39 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
That's a good tip, thanks.
I lay a straight edge in the grooves but lacking the proper bolts to hold
the pulley on at the time, I could either hold the pulley and the iphone, or the pulley and the straightedge
but not both at the same time.
Rich H.
Esse Quam Videri
Page 2 of 3 1 2 3
