Page 1 of 3 1 2 3
A little 572 update with ugly pictures #2763439
04/13/20 01:22 PM
04/13/20 01:22 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Congrats to anyone with a long enough attention span to remember anything about this.
I should title this "I get by with a little help from my friends"
It's coming along, been like a year now if I remember correctly.
Needed the damper hub honed out, Doug hooked me up with Dave,
Dave took care of me on the spot. As luck would have it, I caught him
resizing a set of 4.0 Jeep connecting rods.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763441
04/13/20 01:24 PM
04/13/20 01:24 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Made some Zippycore plug wires the other day (Taylor, not shown).
Working on pulley alignment and alternator, mostly.
I'm told the intake is on backwards, mostly because the two bosses in front look a little silly.
As you can see it's not bolted on, it's just holding the masking tape in place for now.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763443
04/13/20 01:26 PM
04/13/20 01:26 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Decent for cooling, but not enough WP hub stick out left for the fan if I move the WP pulley forward.
And not enough material to cut off the crank pulley.
Probably work fine with a stock damper, but guess what.....
So that shiny March part goes back in the basement.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763445
04/13/20 01:27 PM
04/13/20 01:27 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
The little discontinued Moroso with an AR spacer would almost work.
Notice how the edges are all chipped and banged up. I can't find these new anymore,
so I pick up used ones where I find 'em. I've had the same one on the 451 for a long time.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763447
04/13/20 01:29 PM
04/13/20 01:29 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Chopped off .125" and cleaned up the edges.
That's one of the reasons I like the Moroso pulley!
The center is solid and you can just cut it to whatever you need.
Need to cut off 1/4", even 3/8" no problem....there's plenty of material.
But......it's discontinued.
That's my buddy Todd in the picture.
Todd has taught me all kinds of cool $%-+ over the years for which at this point I can never really repay him
except to use the info, pass it along and teach others. For openers, the frame connectors and roll bar
in my GTX are a collaboration between us but car stuff is just the tip of the iceberg.
Believe me when I tell you: Todd is a technical guy's technical guy.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763450
04/13/20 01:30 PM
04/13/20 01:30 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Faced a buggered bolt hole on the Bridgeport.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763451
04/13/20 01:31 PM
04/13/20 01:31 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Perfecto.
(Now, if I only had the right bolts to hold it on)
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763459
04/13/20 01:37 PM
04/13/20 01:37 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Looks like I don't have to use a Gucci/Powermaster alternator if I don't want to.
Here's a 120 amp Denso from a 1990 Ram that looks like it will probably work.
The external regulator it requires doesn't really bother me (and also doesn't necessarily
need to be mounted on the firewall/can be hidden).
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763461
04/13/20 01:39 PM
04/13/20 01:39 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Lines up reasonably well, or will, with the right spacer combination.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763463
04/13/20 01:39 PM
04/13/20 01:39 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Next steps.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763471
04/13/20 01:52 PM
04/13/20 01:52 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
That's about it for now.
Most ridiculous observation ever:
It sure takes a giant pile of 1/4-20s to dink around with Hemis.
If you want to try a few intakes and valve covers out, between the two there are 36 bolts.
Between the 3 intakes and two sets of valve covers i want to try out, all the lengths of everything have to be different.
48 bolts to try 3 intakes.
40 bolts to try two valve covers.
I mean, that seems like alot.
They sure didn't spare the 1/4-20s on this engine design.
If you weren't entertained by this thread, I only ask you to please consider what it cost you....
thanks-
Rich
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763486
04/13/20 02:48 PM
04/13/20 02:48 PM
tboomer Online work
tboomer  Online Work
Looks good Rich! Keep the pics coming! wave
Re: A little 572 update with ugly pictures [Re: tboomer] #2763493
04/13/20 03:13 PM
04/13/20 03:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very cool thread.
I enjoy seeing the minutia of what it takes to put a Hemi together as I have never owned one and probably never will!
'63 Dodge 330
11.19 @ 121 mph
Re: A little 572 update with ugly pictures [Re: GY3] #2763549
04/13/20 05:20 PM
04/13/20 05:20 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Being this far into it, I totally understand why people don't want to mess with them. The mystique adds to the fun.
I got around a whole lot of potentially frustrating situations by deciding I didn't care when it got done, and focusing on the next step. I was the same way with my 451.
Rich H.
Esse Quam Videri
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763556
04/13/20 05:31 PM
04/13/20 05:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Great progress Rich !!!
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763574
04/13/20 06:34 PM
04/13/20 06:34 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Even though there's headaches they look cool when finished.
Re: A little 572 update with ugly pictures [Re: ZIPPY] #2763637
04/13/20 08:27 PM
04/13/20 08:27 PM
Idaho
LaRoy Engines Offline
Idaho
A 55 gal drum of 1/4" bolts and every part needed some sort of adjustment.........2 Hemi builds (528 & 572) was all I could stand.......never again.
Re: A little 572 update with ugly pictures [Re: LaRoy Engines] #2763692
04/14/20 01:00 AM
04/14/20 01:00 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Kepp plugging away Zippy! up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: A little 572 update with ugly pictures [Re: DynoDave] #2763732
04/14/20 08:30 AM
04/14/20 08:30 AM
NC
440Jim Offline
440Jim  Offline
NC
Zippy, thanks for the post(s).
I guess a 2nd Gen Hemi is not in my future. With the screen name "440Jim", that is OK, LOL. smile
I went through a bunch of small fitting issues with my KB aluminum block, Indy 440-1 headed engine in an A-body Dart. But nowhere near what you have experienced.
The lathe and Bridgeport help... thumbs
Re: A little 572 update with ugly pictures [Re: 440Jim] #2763733
04/14/20 08:35 AM
04/14/20 08:35 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Definitely run the bigger alternator. I wish I had. The way mines set up it would be a major undertaking to do it now.
Doug
Page 1 of 3 1 2 3
