Torssion bar rust #2762753
04/11/20 04:21 PM
04/11/20 04:21 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
what do you think about the heavy pitting on this torsion bar is it junk ? it is a big block 1974 charger . Bar is 43 and 9/16 long number 660r 470 stamped below it . Is it a break waiting to happen ? just do not have 450 for new ones . firm feel seems to be the only place that has them. thanks
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: Torssion bar rust [Re: sparcy] #2762825
04/11/20 07:35 PM
04/11/20 07:35 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Considering the $$ it would take to replace that, I would not call it junk. If you have the budget and it bothers you. Replace it.
I would make a mild attempt at polishing that bar, then painting it. Will it break? Looks easy to answer yes but I've had 20 to 30 daily driver's that had rusted bars, in fact rusted everything and none of them broke. In fact on the 1st few I even had vise grip marks too and again, none of mine broke. Think of how many cars out there that have some rust on their coil springs, if it's only surface rust, they don't break either.
Not saying I've never seen it. I drove tow truck for 5 years, I saw it all but the broken springs were on neglected cars with about 97% more rust than your bar.
Re: Torssion bar rust [Re: Magnum] #2763186
04/12/20 08:25 PM
04/12/20 08:25 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I'd replace it. Not saying it will break, but no guarantees that it won't. I rebuilt the front end on a '57 Coronet a couple of years ago. One torsion bar was badly pitted at one end. I had the customer buy a new pair. They were expensive (about $600), but I could not have given him any kind of guarantee otherwise.
Re: Torssion bar rust [Re: Jim_Lusk] #2763192
04/12/20 08:40 PM
04/12/20 08:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have the original 6 cylinder bars in my 64 Belvedere racecar. The left bar was really pitted after sand blasting, worse than yours. 7 years and over 630 passes later its still fine. Car wheelies on every pass. Run it
Doug
Re: Torssion bar rust [Re: dvw] #2763201
04/12/20 09:05 PM
04/12/20 09:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Run it and don't look back. You can always find one if you need it. I would clean it and paint it. In Michigan back in the day these were rusted in no time and never failed for rust. Springs break because they can. When who knows. The junk on the market now days may fail before your old one would.
Re: Torssion bar rust [Re: NITROUSN] #2763219
04/12/20 10:31 PM
04/12/20 10:31 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'd be worried if you had gouges or nicks as they are stress risers. Some will argue that a pit is a stress riser also but with your case I'd heavily bead blast the bars to remove any corrosion and soften the profiles. Then I'd prime, paint, enjoy.
Re: Torssion bar rust [Re: 6PakBee] #2763235
04/13/20 12:05 AM
04/13/20 12:05 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I have only seen 1 bar ever break and that was on a C-body. I used to clamp vise grips on them and beat them out with a hammer and still never broke one.
No, I don't do it like that anymore.
Re: Torssion bar rust [Re: slantzilla] #2763385
04/13/20 11:57 AM
04/13/20 11:57 AM
moparx Offline
moparx  Offline
if it were mine, i would use steel shot to blast it with.
just my opinion, your results will vary.
beer
Re: Torssion bar rust [Re: moparx] #2763743
04/14/20 09:07 AM
04/14/20 09:07 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
beer
If you have access to a shot peener, this would be a good move. I would recommend glass beading it first to make sure there is no corrosion left.
Re: Torssion bar rust [Re: sparcy] #2763785
04/14/20 11:04 AM
04/14/20 11:04 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Can’t go wrong with an upgrade from Firm Feel.
Abe Lincoln
