Best compression for max power on methanol? #2763033
04/12/20 12:46 PM
04/12/20 12:46 PM
gregsdart Offline OP
Title says it. What would you or do you run?
Re: Best compression for max power on methanol? [Re: gregsdart] #2763038
04/12/20 12:57 PM
04/12/20 12:57 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
15:1 if NA. 12:1 if boosted.
Re: Best compression for max power on methanol? [Re: gregsdart] #2763043
04/12/20 01:07 PM
04/12/20 01:07 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The only methanol engines that I have personally messed with have all been big block Chevys at 582-632 cubes have all been 14.7 or more usually around mid to low 15's. They have cams in the 285 range at 50 on the intake and 310 range at 50 on the exhaust.
Re: Best compression for max power on methanol? [Re: gregsdart] #2763115
04/12/20 04:17 PM
04/12/20 04:17 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I use meth and am at 12.5 . I would think or from what I have read this is almost as low as you want to be. I don’t know that there is a max / perfect compression. I would think it is a combo as with any set up.
Re: Best compression for max power on methanol? [Re: gregsdart] #2763164
04/12/20 07:18 PM
04/12/20 07:18 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There is a point where more compression needs a very complex dome shape with big valve reliefs which masks the valves during overlap. Torque goes up, but peak power doesn't because high RPM VE is down.
This is worst with a "real" hemi like the Gen-2 426, and somewhat in BBC, Ford 385, Cleveland because of the valve angles. A wedge with nearly vertical valves and long stroke can run CR than these.
It also varies with bore/stroke ratio: longer strokes have more compact chambers for the same displacement and static CR.
You won't get the same benefit with lower CR, but I assure you that sidevalve engines with 6:1 CR and huge cams like methanol a lot.
Boffin Emeritus
Re: Best compression for max power on methanol? [Re: polyspheric] #2763197
04/12/20 08:48 PM
04/12/20 08:48 PM
I follow on the dome issue. Mine is .078 high and flat so no problem there. I was told a long time ago (2002) that 15.25 to 15.5 was about max due to more compression wanting a tuneup that negated any gains, plus it got harder on parts. I am curious if that has proven to be the case with 440-1 strokers. Since 2002 I would expect there have been a number of big motors built with 15+ compression.
Re: Best compression for max power on methanol? [Re: Mopar_Rich] #2770487
05/02/20 04:09 PM
05/02/20 04:09 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
That greatly depends on how much boost. We use less than 12:1.
Re: Best compression for max power on methanol? [Re: BobR] #2770578
05/02/20 10:24 PM
05/02/20 10:24 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I went to 15.5 to 1 compression using custom Diamond pistons with a dome shape to match the Indy 440-1 heads. Makes good HP at 976hp...
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Best compression for max power on methanol? [Re: cudabin] #2770631
05/03/20 03:07 AM
05/03/20 03:07 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I run 15:1 498CID B1-BS Head
Re: Best compression for max power on methanol? [Re: Biginchmopar] #2770661
05/03/20 08:36 AM
05/03/20 08:36 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Works great at 11:1 too and I know guys running far less with great results.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best compression for max power on methanol? [Re: pittsburghracer] #2770666
05/03/20 09:00 AM
05/03/20 09:00 AM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
i'm going to give it a try at 11:1 on my 360''. a few racers around here have had awesome results with 10.5-11:1 compression.
