Need help with RB raised cam 48 degree camshaft #276223
04/03/09 07:13 PM
04/03/09 07:13 PM
Chi-Town
PlumCrazyCharger Offline OP
Chi-Town
Well ordered the new cam from Bullet a few weeks back and got a call saying they can't get a cam core. Anyone have any ideas?? Need a RB Raised Cam standard cam bearings with 48 degree lifter angle. Any ideas???
Re: Need help with RB raised cam 48 degree camshaft [Re: PlumCrazyCharger] #276224
04/04/09 12:33 AM
04/04/09 12:33 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
We use LSM and Comp,We are a Dealer for both, call me on monday and I will check both for you.Are you sure on the 48 degree for a wedge?
Re: Need help with RB raised cam 48 degree camshaft [Re: PETE@BESTMACHINE] #276225
04/04/09 11:36 AM
04/04/09 11:36 AM
Chi-Town
Chi-Town
Yes on the 48 degree. I checked double checked with a45 degree cam and then tried a 48 degree cam. My machine shop Ted at Opel Engineering mentioned that KB did the 48 degree to a lot of Wedge Blocks. The lifter bores are bushed.
With the 45 degree cam the no. 1 intake lobe was full lift and 180 degrees after the no.6 intake lobe was at full lift around 8 degrees early/late can't remember which one.
Tried a friends hemi 48 degree cam (used the exhaust lift instead of intake on no.6)and the no.1 intake lobe was at full lift and 180 degrees after the no.6 intake (hemi exhaust) was at full lobe lift at exactly 180 degrees later.
Any other ways to check? The whole short block is assembled and really don't want to disassmble again if not needed. I think the above test helped determine the 48 degree angle.
Re: Need help with RB raised cam 48 degree camshaft [Re: PlumCrazyCharger] #276226
04/04/09 02:23 PM
04/04/09 02:23 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
My KB stage 7 block i have has 48 degree lifter bores too. Your checking it the right way.
Who ever had my engine before had put a 45 degree cam in it with out knowing, things just dont run right.
Ill be going ot comp for my cam
