Trans crossmember spacers which way? #2759748
04/04/20 09:30 AM
04/04/20 09:30 AM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
The rectangle spacers that go on the transmission crossmember do they go between the trans and member or underneath with the bolt? Looking at the factory manual it looks like it goes underneath but that basically makes it a big washer and not a spacer shruggy Thanks, Lou
Lou P.
Newark DE
Re: Trans crossmember spacers which way? [Re: Dogpro] #2759769
04/04/20 10:46 AM
04/04/20 10:46 AM
N
NITROUSN Offline
NITROUSN  Offline
N
They are on the bottom against the nut or bolt.
Re: Trans crossmember spacers which way? [Re: NITROUSN] #2760313
04/05/20 10:44 AM
04/05/20 10:44 AM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
Thanks for the info up
Lou P.
Newark DE
Re: Trans crossmember spacers which way? [Re: Dogpro] #2761420
04/08/20 10:46 AM
04/08/20 10:46 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
They are not spacers, they are just rectangle washers.
Jeff
Re: Trans crossmember spacers which way? [Re: Cuda340] #2761529
04/08/20 02:57 PM
04/08/20 02:57 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the price they charge for rectangle washers just for show that no one will ever see..I was that Sucker..lol
Re: Trans crossmember spacers which way? [Re: AARCONV] #2762169
04/10/20 08:21 AM
04/10/20 08:21 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
reinforcement washer, under bolt head, covers more area then round washer, most mounts had slotted holes
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Trans crossmember spacers which way? [Re: AARCONV] #2762504
04/10/20 09:41 PM
04/10/20 09:41 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
easy to make for a dime.
Re: Trans crossmember spacers which way? [Re: sixbbl 69] #2762775
04/11/20 05:27 PM
04/11/20 05:27 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Just for the record,the one on the right are OEM Mopar.The one on the left are from a 1969 Chevelle I'm working on.
