bump steer kit for 72 A body #2761219
04/07/20 06:46 PM
04/07/20 06:46 PM
Az
HOT IN AZ Offline OP
Az
This might be an old subject but I need a bump steer kit for a 72 A body Mopar with stock front suspension. Car is used for drag racing and must retain stock front suspension to be legal. Tie rod assemblies can be changed. I know about lowering the steering box and idler arm which have been done. Have also heard of shimming the lower ball joint which I have not. Hotchkis seems to be the only one to make a kit but was looking for other sources or info. Thanks in advance, Rick
Re: bump steer kit for 72 A body [Re: HOT IN AZ] #2761249
04/07/20 08:12 PM
04/07/20 08:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
https://www.speedwaymotors.com/Adjustable-Tie-Rod-Adapter-Stud-to-Heim,3333.html
QA1 PCYML10T High Misalign Chromoly Heim Joint Rod Ends 5/8-18 LH Male
Universal Fit, LH Male Thread Type, Male Threads/Eyelet Rod End Attachment, Chromoly, Black
https://www.speedwaymotors.com/5-8-Inch-Chromoly-Swedged-Tubes,49536.html?sku=91034558-13&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=EAIaIQobChMIubC55MTX6AIVxJJbCh38gwgyEAQYASABEgJ2b_D_BwE
I used these. The Pinto taper is the same as Mopar. You may have to take a little off the bottom of th eballjoint where the outer tie rod set. You want it to set only on the taper, Not the hex. I ground about .060" off my Belvedere. I used 5/8"x18 threaded tube and cut the stock tie rod sleeves in half. Welded the tube over the remaining half of the sleeve. Mopar uses oddball 9/16 tie rod threads so you have to adapt. Blow up the picture and you can see.
Doug
