Heater cable-1983 D150 #2761161
04/07/20 04:02 PM
04/07/20 04:02 PM
stratford,ontario,canada
JD340 Offline OP
JD340  Offline OP
Need some help finding out the part number for the heater control cable on my 83 D150, mine's broken. No numbers I can find on it. Where could I look up to find a number for it so I can possibly find a replacement? Any help is appreciated!
Nothing to see here. Carry on.
Re: Heater cable-1983 D150 [Re: JD340] #2761166
04/07/20 04:24 PM
04/07/20 04:24 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
A few years of those are the same as the 83, how bout a junkyard?
Re: Heater cable-1983 D150 [Re: volaredon] #2761179
04/07/20 04:39 PM
04/07/20 04:39 PM
JD340 Offline OP
JD340  Offline OP
Pretty slim pickin's for old goats around here anymore. Picked one up off a 91 or 92 and it was about 8" shorter! down
Re: Heater cable-1983 D150 [Re: JD340] #2761182
04/07/20 04:43 PM
04/07/20 04:43 PM
Guitar Jones Offline
There are places that can make cables. I thought I had one saved in my favorites but I don't have access to my PC now. Maybe a google search?
Re: Heater cable-1983 D150 [Re: Guitar Jones] #2761194
04/07/20 05:21 PM
04/07/20 05:21 PM
JD340 Offline OP
JD340  Offline OP
That might just be an option if I cant find a replacement. My original is stamped TEFLEX CORPORATION or INCORPORATED I forgot right now. I wonder if they're still around? work
Re: Heater cable-1983 D150 [Re: JD340] #2761241
04/07/20 07:50 PM
04/07/20 07:50 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I bet a throttle cable off an old junk lawnmower can be cut down and used. I made a manual choke cable out of one.
Otherwise, like Jonsey says about having one made. Motorcycle shops can make one up for you.
Mo' Farts
Moderated by "tbagger".
Re: Heater cable-1983 D150 [Re: Grizzly] #2761299
04/07/20 10:47 PM
04/07/20 10:47 PM
ND
dodgedon Offline
dodgedon  Offline
ND
I may have one. How long is it?
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Heater cable-1983 D150 [Re: JD340] #2761374
04/08/20 08:09 AM
04/08/20 08:09 AM
s.d.
K
kermit1 Offline
kermit1  Offline
K
s.d.
i got one from mega parts for my 78 d150 i ordered it for a 70-74 e body non air worked great correct ends. look into it.part number 108-fp315. good luck
Re: Heater cable-1983 D150 [Re: JD340] #2761394
04/08/20 09:26 AM
04/08/20 09:26 AM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
Need to know what system your truck has, I may have one, Regular heat ( No vents in dash ), Bi-Level heat ( vents in dash, no A/C ), or is it an A/C truck ? If regular heat which cable, temp or blend ?
Re: Heater cable-1983 D150 [Re: JD340] #2761565
04/08/20 04:39 PM
04/08/20 04:39 PM
ND
dodgedon Offline
dodgedon  Offline
ND
I have 40" from eye to eye. This one has red tabs.
The other is 27" eye to eye. This one has yellow tabs.
67 Charger 383 auto
Re: Heater cable-1983 D150 [Re: dodgedon] #2761940
04/09/20 02:43 PM
04/09/20 02:43 PM
JD340 Offline OP
JD340  Offline OP
The first one sounds like what I need! Mine also has the red tabs and measures 36" from end to end on the cable housing itself. PM me please sir! up
Re: Heater cable-1983 D150 [Re: Ramtough] #2761942
04/09/20 02:45 PM
04/09/20 02:45 PM
JD340 Offline OP
JD340  Offline OP
Regular heat, no Bi-level, no ac, temp cable is the one I need. up
Re: Heater cable-1983 D150 [Re: JD340] #2762095
04/09/20 09:48 PM
04/09/20 09:48 PM
ND
dodgedon Offline
dodgedon  Offline
ND
Yes, the jacket on the red one is 36". I will send a pm when im on the computer tonight. Its easier....
67 Charger 383 auto
Re: Heater cable-1983 D150 [Re: dodgedon] #2762324
04/10/20 01:48 PM
04/10/20 01:48 PM
JD340 Offline OP
JD340  Offline OP
That looks to be the one Don! up
