Re: degree cam [Re: pittsburghracer] #2764718
04/16/20 06:09 PM
04/16/20 06:09 PM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
Originally Posted by pittsburghracer
Originally Posted by RapidRobert
^^^ it says fits gm/furd lifter .842"/.875" bores. I'm assuming it expands enough to fit ours
This one fits Mopars.
https://www.summitracing.com/parts/pro-66843
Does anyone know of one of these that fits a .937 lifter bore?
I have tried one of the Proform "universal" checkers and it does not fit well.
Thanks!
Re: degree cam [Re: 340Cuda] #2764753
04/16/20 07:03 PM
04/16/20 07:03 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have one of the proform universal checkers, you have to expand it to its maximum but it has worked well for me. expand it slowly and rock it a little, until it gets tight in the lifter bore.
I am just so used to, that everything is built to fit a Chevy, and you have to fiddle with it for a Mopar.
Re: degree cam [Re: jwb123] #2764941
04/17/20 09:59 AM
04/17/20 09:59 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
On my bushed R3 block if the checker is loose enough go in its very wobbly at the bottom with no way to tighten it up.
Re: degree cam [Re: 340Cuda] #2764982
04/17/20 11:10 AM
04/17/20 11:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Made my own 25 years ago for solid lifter and roller.Home made piston stop for when the head is on up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: degree cam [Re: pittsburghracer] #2765380
04/18/20 09:46 AM
04/18/20 09:46 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
where did you get that long extension on the top. mine didnt come with that.im using mine on a world alum. block and the guage hits the block so i have to turn it away from me to make it work.it still works great just a bit of a pain.
Does that fit in a small block with the dial indicator on it???? Seems like it’s awful long and the indicator would hit the block.
Yep it works great on small blocks. I just did my new 408 a few weeks ago
