Re: degree cam
[Re: bonefish]
#2760659
04/06/20 10:00 AM
04/06/20 10:00 AM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
“At the cam” would be with a lifter, or some sort of tool that simulates the lifter.
Any numbers you got by trying to use the end of an indicator on the lobe would be pretty much useless.
Re: degree cam
[Re: jwb123]
#2760697
04/06/20 11:21 AM
04/06/20 11:21 AM
RapidRobert
^^^ it says fits gm/furd lifter .842"/.875" bores. I'm assuming it expands enough to fit ours
Re: degree cam
[Re: RapidRobert]
#2760702
04/06/20 11:37 AM
04/06/20 11:37 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
^^^ it says fits gm/furd lifter .842"/.875" bores. I'm assuming it expands enough to fit ours This one fits Mopars. https://www.summitracing.com/parts/pro-66843
Re: degree cam
[Re: RapidRobert]
#2760718
04/06/20 12:17 PM
04/06/20 12:17 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You are very welcome. I have both of them as I degree in Cams for some Chevy and ford friends and you will love it. It makes the job so much easier.
Re: degree cam
[Re: RapidRobert]
#2760730
04/06/20 12:37 PM
04/06/20 12:37 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John it sounds like a must have tool (ain't they all!) Man I love tools. I don’t use them all but I gotta have them. Next big purchase if cronaviras doesn’t get me will be Harbor Freights big horizontal metal saw. I’ve had my eye on it. Man I’m addicted to buying LED flashlights.
Re: degree cam
[Re: pittsburghracer]
#2760748
04/06/20 01:32 PM
04/06/20 01:32 PM
Posts: 4,457 Washington
madscientist
Washington
Does that fit in a small block with the dial indicator on it???? Seems like it’s awful long and the indicator would hit the block.
Re: degree cam
[Re: madscientist]
#2760754
04/06/20 01:44 PM
04/06/20 01:44 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Does that fit in a small block with the dial indicator on it???? Seems like it’s awful long and the indicator would hit the block. Yep it works great on small blocks. I just did my new 408 a few weeks ago
Re: degree cam
[Re: bonefish]
#2760757
04/06/20 01:46 PM
04/06/20 01:46 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I use to always check the lobe separation angle at the retainers, same on verifying cam timing until one of the racer reps at Comp said that is not the way they want you to check the cam lobes due to rocker arm ratio affecting the cam timing, which it does I now check the cam timing on the lifters (and adjust the cam timing as needed) and verify the cam advance on the lobe centers by verifying the intake lobe center first and then both of them after I get the intake lobe where I want it by checking them at the retainers and then verifying the exhaust lobe separation angle to make sure the lobe separation angle is ground correctly on every cam If the cam is ground on a 108 LSA and it is installed at 4 degrees advance so the intake lobe center is at 104 degree after top dead center the exhaust lobe max lift, lobe center, should be at 112 degrees BTDC If it isn't like that the cam LSA is ground wrong. I've had several custom ground "racing" cam that where not ground on the LSA that was on the cam card I also check the LSA at .050, .100 and .200 before and after max lift on all the lobes I check If the lobes are within one degree of each other at all three checking LSA heights I use that cam You can't be to careful
Re: degree cam
#2760775
04/06/20 02:51 PM
04/06/20 02:51 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Does that fit in a small block with the dial indicator on it???? Seems like it’s awful long and the indicator would hit the block. Yep it works great on small blocks. I just did my new 408 a few weeks ago I love that pointer.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: degree cam
[Re: poboyengineering]
#2760779
04/06/20 03:01 PM
04/06/20 03:01 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
LOL. That pointer is custom made and has more cam degree credits than I care to divulge. LOL
Re: degree cam
#2761097
04/07/20 01:02 PM
04/07/20 01:02 PM
Posts: 19,388 north of coder
moparx
Man I’m addicted to buying LED flashlights. me too ! but i wished hobo fright would offer a 14" metal cutting cold saw. i have looked on line at a bunch, and i'm not real satisfied with what i see, no matter what the cost is. well, that is excluding those for $800.00 plus. i'm almost tempted to build one, but i have too many projects now as it is !
