Houston, we have a problem...... #2760514
04/05/20 08:11 PM
04/05/20 08:11 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Houston, we have a problem...... (crackle) the warp drive in the 440 has failed.........
Re: Houston, we have a problem...... [Re: Alaskan_TA] #2760517
04/05/20 08:16 PM
04/05/20 08:16 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Why did you go and do that?
STOP POTATO HATE!
Re: Houston, we have a problem...... [Re: Mr PotatoHead] #2760519
04/05/20 08:22 PM
04/05/20 08:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Over rev it a bit?
Low oil pressure?
Collapsed lifters?
Damaged rockers?
Broken camshaft?
Time to pull the intake and see if the lifters are still in place. If you got y with just a couple bent push rods, your pretty lucky. Gene
Re: Houston, we have a problem...... [Re: poorboy] #2760521
04/05/20 08:28 PM
04/05/20 08:28 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
1968 engine, parked in 1981 with less than 9K miles on it.
2 stuck valves.
I'll get it running yet. :-)
Look at how clean it is inside, just amazing.
Re: Houston, we have a problem...... [Re: Alaskan_TA] #2760550
04/05/20 09:45 PM
04/05/20 09:45 PM
Guitar Jones Offline
Stop picking at that or it will never heal.
Re: Houston, we have a problem...... [Re: Guitar Jones] #2760556
04/05/20 09:51 PM
04/05/20 09:51 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Did the stuck valves meet the pistons? work
Re: Houston, we have a problem...... [Re: DrCharles] #2760557
04/05/20 09:58 PM
04/05/20 09:58 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Stuck closed, so I do not see how.
Re: Houston, we have a problem...... [Re: Alaskan_TA] #2760564
04/05/20 10:11 PM
04/05/20 10:11 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's good... last time I saw two pushrods like that (on a core 383 I bought cheap), a rod had broken at high rpm and the piston came up and CLOSED the valves. It wasn't pretty inside.
Re: Houston, we have a problem...... [Re: Alaskan_TA] #2760568
04/05/20 10:17 PM
04/05/20 10:17 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
What car is that? work
JB Rhinehart, Realist
A-Body's RULE!
Re: Houston, we have a problem...... [Re: Rhinodart] #2760589
04/05/20 10:58 PM
04/05/20 10:58 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
My wagon's original 400 had a pushrod like that. The engine had a spun rod bearing and the extra play in the rod allowed it to smack the head a time or two.
Strangely enough though, the valve wasn't damaged. shock You could see on the piston where contact was made but it wasn't 'hammered'. After checking that the valve stems were straight, I lapped the valves in place and put the heads on the 440 block currently in the wagon. Never had an issue.
shruggy
John
Re: Houston, we have a problem...... [Re: Rhinodart] #2760596
04/05/20 11:29 PM
04/05/20 11:29 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
When I bought my 78 LRT in 1994 it was going cheap. I was the 5th person to look and test drive it. It ran like crap.
I paid the $1200 cash and drove it the 12 miles home and it was way down on power. Doing 45 MPH, I lost speed climbing a long hill going home. I parked it for a week. This is when I found out the engine was a 1978 Warranty replacement E58.
I pulled a compression test and all were at about 145 PSI but #3 was way down, like 80 PSI WET.
Took the valve cover off and found the #3 intake rocker's push rod cup was broken out, windowed but still attached. Push rod was OK but the lifter was almost popped out of its bore. Using my 2.2 coil spring compressor I could push the valve down with no binding. Took a spare rocker and put it back together. Ran excellent. Never another issue in the 200,000 miles I drove it
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Houston, we have a problem...... [Re: Dave_J] #2760653
04/06/20 09:47 AM
04/06/20 09:47 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I know people are looking for things to keep busy during quarantine, but you didn't have to go that far...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Houston, we have a problem...... [Re: Alaskan_TA] #2760676
04/06/20 10:44 AM
04/06/20 10:44 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
A couple of new dilithium crystals and you'll be back in business chop-chop.
Re: Houston, we have a problem...... [Re: Dave_J] #2760726
04/06/20 12:31 PM
04/06/20 12:31 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Had exact same issue with a 75 dart 4door 318 . . ran like crap . . .pulled left hand valve cover - yup, one rocker arm had pushrod through it . . . took old rocker from another head, pushrod was still ok, buttoned up and ran like champ !! Gotta love those cheap fixes ! Think I paid $350 for the car, and put another $350 into it (tires, brakes) and drove it for a few years, and sold for $1k ! . .
Re: Houston, we have a problem...... [Re: a12rag] #2760879
04/06/20 08:01 PM
04/06/20 08:01 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Those manifolds????
Re: Houston, we have a problem...... [Re: Michael] #2760881
04/06/20 08:11 PM
04/06/20 08:11 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted by Michael
Those manifolds????
C body specific
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Houston, we have a problem...... [Re: 3hundred] #2761052
04/07/20 10:49 AM
04/07/20 10:49 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Would it not be smart to pull the heads, at least clean the stems and guides, maybe touch the seats and valves, and change those likely rusted thru at the water jacket steel head gaskets before you destroy a low mile motor? I also see guys run old gas from a poorly cleaned tank thru a motor and stick the valves.
Re: Houston, we have a problem...... [Re: 4406bbl] #2761062
04/07/20 11:06 AM
04/07/20 11:06 AM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I have been here before.
Once the valves move freely again it should be fine.
I hooked new non-ethanol gas to the fuel pump & flushed it and the fuel line to the carb out with a priming / pump hose from an old outboard motor.
New filter & hoses installed after that.
The squeeze bulb is also great for priming the carb at that point.
The car is rusted bad, so I want to hear the engine run once to see if the transmission shifts OK before I pull it inside to strip.
The valve on #1 has already moved some.
Penetrating oil, time & patience.....
Re: Houston, we have a problem...... [Re: Alaskan_TA] #2761100
04/07/20 01:06 PM
04/07/20 01:06 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Barry, What are you going to do with the rest of the car once the engine is pulled? shruggy
I know somebody looking for one... twocents
...FAFO...
Re: Houston, we have a problem...... [Re: skicker] #2761113
04/07/20 01:39 PM
04/07/20 01:39 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I have a very good friend with one, so several parts will be set aside.
After that I have another pal with the exact same model too.
So some 'dibs' have already been claimed.
When they are done, I'll have to asses what is left.
