Re: 440 Nitrous Profile Camshaft?
[Re: 2qik4u]
#276028
04/03/09 07:08 PM
04/03/09 07:08 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
It will be a 440 with 9.3 to 1 forged pistons, polished factory rods, factory crank, ARP rod bolts. I'm looking for an NOS grind cam. Comp Cams has NOS grinds for Chevy, don't see anything Mopar. Spoke with Summit, Jeg's, and Mancini; nobody on the tech line has been able to direct me to a NOS specific grind cam for Mopar.
I believe 113-115 lobe separation, split duration with more on the exhaust side, and low lift are the keys to a good NOS profile. Anyone know of a good profile for a 440? I'll be running 150 shot and would like to maximize e.t. while on the bottle.
Thanks to anyone who has info. Monte Smith? Others?
Hyd. cam? Solid FT cam? Solid roller cam? Hyd. roller cam? It helps to know this stuff. I can tell you, with low compression, you'll want to keep the lobe center around 110, advance it maybe 2-3°. What about exhaust, like headers, sizes...what I'm getting at is you'd be best off with a custom cam. And we can help. I'm a Comp dealer, and engine builder. Tell us more, more, more! Brian
Brian Hafliger
[Re: 2qik4u]
#276032
04/03/09 10:03 PM
04/03/09 10:03 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
with that little of a shot and the static comp ratio...your running.. forget a nitrous cam...its a waist of time. just put the best cam in it to make the best power N/a...you have now based on your heads flow curve...and valve peaks..... choose a cam for that...
then throw the 150 shot on that... it will run just as fast...
it will be a dog on the street with a no2 cam. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: goldmember]
#276034
04/03/09 10:19 PM
04/03/09 10:19 PM
Posts: 4,689 On the parachute mount
n20mstr
i had a 440 in my car 3600lbs, 9.7 compression .509 hyd cam with stock rockers 906 heads with valve job and home pocket port holly street dominator intake 850 carb pro parts headers 10" comverter 727 3.90 rear gears full 3" exh nitrous plate with 93/82 jet 225hp?
car ran 12.30 on motor 10.70 with nitrous
....BAD A$$ STREET CAR.....
[Re: Plumb Wired]
#276038
04/04/09 09:41 AM
04/04/09 09:41 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
as well. Your over thinking this combo. Keep it simple, the NOS will work fine on its own in this application.
RIP Monte Smith
[Re: Brian Hafliger]
#276041
04/04/09 04:31 PM
04/04/09 04:31 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I am also a fan of solids.
If you want a hydraulic, I can get you an Engle grind in a somewhat standard nitrous format 230, 244 duration,lift .514,.539 113 lobe sep.
These lifters wont pump up when using adjustable rockers and no preload.
PM me if interested.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
