Re: May daughter is graduating as a PA, now Covid
[Re: 71TA]
#2760311
04/05/20 10:40 AM
04/05/20 10:40 AM
Posts: 12,186 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A little perspective is in order. For certain individuals, this virus is a very real threat. But for healthy folks under about 54 years old with access to medical treatment, the fatality rate appears to be under 1%. In some studies, as low as .6%. Other Coronaviruses such as SARS have had a much higher mortality rate. The real issue is protecting and treating those who are at most risk of severe reactions to this. But for the vast majority of us, it is nothing more than a cold. The following is not the only source of this information. Other reliable sources report similar rates. https://www.livescience.com/is-coronavirus-deadly.html
Master, again and still
[Re: DaveRS23]
#2760366
04/05/20 12:40 PM
04/05/20 12:40 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
A little perspective is in order. For certain individuals, this virus is a very real threat. But for healthy folks under about 54 years old with access to medical treatment, the fatality rate appears to be under 1%. In some studies, as low as .6%. Other Coronaviruses such as SARS have had a much higher mortality rate. The real issue is protecting and treating those who are at most risk of severe reactions to this. But for the vast majority of us, it is nothing more than a cold. The following is not the only source of this information. Other reliable sources report similar rates. https://www.livescience.com/is-coronavirus-deadly.html While what you write is true the way I see it the real problem with this virus is how easily it is transmitted with a rate somewhere around 3X what the flu or other Corona viruses were transmitted. And that is the crux of the problem. With the ability to infect probably nearly the entire world population the mortality rate could be something like the human race has never seen before. Just look at how fast this has spread world wide. I know some believe this to be over blown but just think where we might be right now if none of these measures were taken. Think about it.
[Re: Guitar Jones]
#2760370
04/05/20 12:44 PM
04/05/20 12:44 PM
Posts: 3,903 Oregon
hooziewhatsit
A little perspective is in order. For certain individuals, this virus is a very real threat. But for healthy folks under about 54 years old with access to medical treatment, the fatality rate appears to be under 1%. In some studies, as low as .6%. Other Coronaviruses such as SARS have had a much higher mortality rate. The real issue is protecting and treating those who are at most risk of severe reactions to this. But for the vast majority of us, it is nothing more than a cold. The following is not the only source of this information. Other reliable sources report similar rates. https://www.livescience.com/is-coronavirus-deadly.html While what you write is true the way I see it the real problem with this virus is how easily it is transmitted with a rate somewhere around 3X what the flu or other Corona viruses were transmitted. And that is the crux of the problem. With the ability to infect probably nearly the entire world population the mortality rate could be something like the human race has never seen before. Just look at how fast this has spread world wide. I know some believe this to be over blown but just think where we might be right now if none of these measures were taken. Think about it. 1% doesn't sound bad, until you apply it to 300 million people... This virus hit the sweet spot of highly contagious and a relatively high mortality rate.
[Re: hooziewhatsit]
#2760380
04/05/20 01:16 PM
04/05/20 01:16 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Some more perspective; according to the CDC, there are between 12,000 and 61,000 U.S. deaths annually due to influenza. We have just now reached 9,000 Covid related deaths here. https://www.cdc.gov/flu/about/burden/index.html
[Re: GoodysGotaCuda]
#2760382
04/05/20 01:17 PM
04/05/20 01:17 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Horrible, I just hope they get the local and Federal support they need.
There are still states that do not have stay-at-home orders in place yet. It's like the Katrina response all over again, just Nationwide.
Are medical professionals are being sent to the front lines without a firearm and have nothing to support their family if they are killed in action. This will change the course of our medical system. The reason to do stay-at-home is not because your state is seeing high rates of the disease, it's to prevent those states not yet hard hit from eventually seeing high rates of the disease. Unfortunately, some states only seem to be reacting after it may be too late to 'flatten the curve'....the virus will come to those states, sooner or later. The USA faced this sort of crisis before, almost 100 years ago. But with time comes the fading of memory and the value of hard-learned lessons. There is an excellent documentary on the 1918 Spanish flu pandemic here... https://www.pbs.org/wgbh/americanexperience/films/influenza/Granted, medicine today has progressed by light years, so has communications. But technology has also enabled disease to cross oceans in a matter of hours, whereas a steam ship in 1918 might take a week or more.
[Re: Sixpak]
#2760449
04/05/20 05:07 PM
04/05/20 05:07 PM
Posts: 4,443 Michigan
MarkZ
Worthy
Worthy
I just don't see Detroit getting anywhere near as bad as New York. The population density just isn't there - half of Detroit is vacant land at this point with around half a million people. New York had nowhere to build, so instead of out, they went up.
[Re: DaveRS23]
#2760451
04/05/20 05:11 PM
04/05/20 05:11 PM
MarkZ
Worthy
Worthy
This is not the normal flu. I keep seeing these numbers compared and it's a false equivalency. The infection rates double every three days and it can take up to two weeks before symptoms present themselves. The funny thing about tsunamis is you don't see them coming until they're right off the tip of your nose.
[Re: MarkZ]
#2760462
04/05/20 05:39 PM
04/05/20 05:39 PM
Posts: 5,470 Michigan
oldjonny
Don't argue with me.
I just don't see Detroit getting anywhere near as bad as New York. The population density just isn't there - half of Detroit is vacant land at this point with around half a million people. New York had nowhere to build, so instead of out, they went up. The problem with Detroit is there are many people that are not incredibly intelligent. There is a large part of the area that is low income and just plain very reliant on the government for everything they do. So, in that vein, probably not much different than parts of NY.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: oldjonny]
#2760471
04/05/20 05:51 PM
04/05/20 05:51 PM
Guitar Jones
I just don't see Detroit getting anywhere near as bad as New York. The population density just isn't there - half of Detroit is vacant land at this point with around half a million people. New York had nowhere to build, so instead of out, they went up. The problem with Detroit is there are many people that are not incredibly intelligent. There is a large part of the area that is low income and just plain very reliant on the government for everything they do. So, in that vein, probably not much different than parts of NY. Hold on a minute, there is huge difference between unintelligent and uneducated. Just because people are poor and uneducated does not mean they are stupid. I've known some very smart people with and without an education that choose to live a different lifestyle.
[Re: oldjonny]
#2760476
04/05/20 06:08 PM
04/05/20 06:08 PM
Sixpak
The Swamp
I just don't see Detroit getting anywhere near as bad as New York. The population density just isn't there - half of Detroit is vacant land at this point with around half a million people. New York had nowhere to build, so instead of out, they went up. The problem with Detroit is there are many people that are not incredibly intelligent. There is a large part of the area that is low income and just plain very reliant on the government for everything they do. So, in that vein, probably not much different than parts of NY. The key is in how soon good, reliable information is communicated to the masses, and then whether they will listen. Just yesterday I saw a group of younger kids here in Florida getting together, not observing social distancing rules, and then going out for things like motorcycle rides. The rides might not be bad, but the meet up before the rides could be. A week ago, I rode my bike to a parking lot (my normal spot to stop for 5 minutes and turn around), for a paved bike trail, and it was packed with cars and people. There was a group of 10 - 15 high school kids, apparently all from the same track team, who were within 2 feet of each other, all waiting to go for a run on the trail. I turned around and got out of there as fast as I could. So a lack of intelligence may not be unique to Detroit, or NY, or Florida. NYC is a whole different ballgame than even a big city like Detroit. NYC is still the epicenter of business world, and international travel to and from NYC has to greater than Detroit, so more chances for the disease to have been introduced much sooner than in other places. Only Los Angeles, and maybe to a degree Chicago come close to NYC, with regard to commerce, International travel and population density.
[Re: MarkZ]
#2760504
04/05/20 07:40 PM
04/05/20 07:40 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This is not the normal flu. I keep seeing these numbers compared and it's a false equivalency. The infection rates double every three days and it can take up to two weeks before symptoms present themselves. The funny thing about tsunamis is you don't see them coming until they're right off the tip of your nose. Well, according to the Mayo Clinic "It's unclear exactly how contagious the new coronavirus is." https://www.mayoclinic.org/diseases-conditions/coronavirus/symptoms-causes/syc-20479963If there is not enough data for the Mayo Clinic to determine just how contagious this virus is in comparison to other infectious diseases, how did you determine that what I posted is a 'false equivalency'? How fast do you think any other cold or flu spreads? Do you have any data on that? Make no mistake, this virus can be fatal in certain instances. But it's mortality rate is not that much different that some other viruses. In fact, the SARS a few years ago had a mortality rate nearly 10 times what this one has. And there is no evidence that Covid-19 is any more contagious. You are are sorta right when you say that this is not the 'normal flu'. Because it is not a flu at all. It's a cold, a chest cold. And there is no evidence that it's transmission rate is any higher than other Coronoviruses. It's just that it's spread has been very well documented. My only point is that it is unclear to many why this particular virus has been given the attention it has. We have new colds and influenzas every single year. Which is why there is a different fly shot every year. A flu shot whose efficacy rate is only 40% to 60% a year. https://www.cdc.gov/flu/vaccines-work/vaccineeffect.htmWhat is it about this particular cold that has us all at a standstill?
[Re: DaveRS23]
#2760510
04/05/20 08:01 PM
04/05/20 08:01 PM
Guitar Jones
What is it about this particular cold that has us all at a standstill? Gee willickers Wally, maybe it's the refrigerated semi trailers stacking up for the bodies or maybe it's the overwhelmed hospitals or maybe it's the bodies stacking up all over the world.
[Re: DaveRS23]
#2760513
04/05/20 08:04 PM
04/05/20 08:04 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
8km This is not the normal flu. I keep seeing these numbers compared and it's a false equivalency. The infection rates double every three days and it can take up to two weeks before symptoms present themselves. The funny thing about tsunamis is you don't see them coming until they're right off the tip of your nose. Well, according to the Mayo Clinic "It's unclear exactly how contagious the new coronavirus is." https://www.mayoclinic.org/diseases-conditions/coronavirus/symptoms-causes/syc-20479963If there is not enough data for the Mayo Clinic to determine just how contagious this virus is in comparison to other infectious diseases, how did you determine that what I posted is a 'false equivalency'? How fast do you think any other cold or flu spreads? Do you have any data on that? Make no mistake, this virus can be fatal in certain instances. But it's mortality rate is not that much different that some other viruses. In fact, the SARS a few years ago had a mortality rate nearly 10 times what this one has. And there is no evidence that Covid-19 is any more contagious. You are are sorta right when you say that this is not the 'normal flu'. Because it is not a flu at all. It's a cold, a chest cold. And there is no evidence that it's transmission rate is any higher than other Coronoviruses. It's just that it's spread has been very well documented. My only point is that it is unclear to many why this particular virus has been given the attention it has. We have new colds and influenzas every single year. Which is why there is a different fly shot every year. A flu shot whose efficacy rate is only 40% to 60% a year. https://www.cdc.gov/flu/vaccines-work/vaccineeffect.htmWhat is it about this particular cold that has us all at a standstill? Considering the mechanics of the disease as far as how it spreads and how it actually infects is pretty much identical to flus and colds, I don't get how it can be 3x or whatever the claim is more contagious. Still no mention of what the total cases might be over and above "confirmed" cases. Begs the question why not? The flu stats were up to 60 million cases, 1 million hospitalizations +/- and 60,000 fatalities. Is this one on track to exceed those numbers? Kevin
[Re: Twostick]
#2760524
04/05/20 08:40 PM
04/05/20 08:40 PM
Guitar Jones
Bug 8km This is not the normal flu. I keep seeing these numbers compared and it's a false equivalency. The infection rates double every three days and it can take up to two weeks before symptoms present themselves. The funny thing about tsunamis is you don't see them coming until they're right off the tip of your nose. Well, according to the Mayo Clinic "It's unclear exactly how contagious the new coronavirus is." https://www.mayoclinic.org/diseases-conditions/coronavirus/symptoms-causes/syc-20479963If there is not enough data for the Mayo Clinic to determine just how contagious this virus is in comparison to other infectious diseases, how did you determine that what I posted is a 'false equivalency'? How fast do you think any other cold or flu spreads? Do you have any data on that? Make no mistake, this virus can be fatal in certain instances. But it's mortality rate is not that much different that some other viruses. In fact, the SARS a few years ago had a mortality rate nearly 10 times what this one has. And there is no evidence that Covid-19 is any more contagious. You are are sorta right when you say that this is not the 'normal flu'. Because it is not a flu at all. It's a cold, a chest cold. And there is no evidence that it's transmission rate is any higher than other Coronoviruses. It's just that it's spread has been very well documented. My only point is that it is unclear to many why this particular virus has been given the attention it has. We have new colds and influenzas every single year. Which is why there is a different fly shot every year. A flu shot whose efficacy rate is only 40% to 60% a year. https://www.cdc.gov/flu/vaccines-work/vaccineeffect.htmWhat is it about this particular cold that has us all at a standstill? Considering the mechanics of the disease as far as how it spreads and how it actually infects is pretty much identical to flus and colds, I don't get how it can be 3x or whatever the claim is more contagious. Still no mention of what the total cases might be over and above "confirmed" cases. Begs the question why not? The flu stats were up to 60 million cases, 1 million hospitalizations +/- and 60,000 fatalities. Is this one on track to exceed those numbers? Kevin Most likely would have if these drastic measures were not taken. Remember if nothing really bad becomes of this, that was the point!
[Re: MR_P_BODY]
#2760527
04/05/20 08:48 PM
04/05/20 08:48 PM
Posts: 1,584 MD
p d'ro
MD
Even with the stay at home order the inner city people are the ones gathering to play hoops in Detroit.. until the city had to take down the hoops They had to do it in my white bread neighborhood too. Dumb ass parents think it cant reach us. Still having playdates and walking to neighbors houses despite stay at home order. This thing infects thru air and when you dont feel or look ill. Just assume everyone has it and you will be ahead of the game
