383 Water Pump/Timing Chain ? ? ?
#2759810
04/04/20 12:53 PM
04/04/20 12:53 PM
Posts: 283 Massachussetts
RCKTMN
Massachussetts
Hello all, I am looking into replacing the water pump and timing chain in my 1970 Chrysler Newport's 383-2V. I am interested in an OEM style recommendation (this is not a performance build). Though I am not against an upgrade if it improves reliability. I drive the car coast-to-coast at times. What are good sources for a water pump and timing chain? Thank you!
1970 Barracuda Convertible 1970 Newport Convertible 1970 Satellite Convertible 1974 'Cuda shell - '71 conversion 1988 Oldsmobile Cutlass w/455 2003 RAM3500 CTD 2007 Caliber R/T AWD 2007 Magnum SRT-8 2016 Chrysler Town & Country
Re: 383 Water Pump/Timing Chain ? ? ?
[Re: Sniper]
#2759838
04/04/20 01:42 PM
04/04/20 01:42 PM
RCKTMN
Massachussetts
Thanks guys. I just checked on Rockauto. Will likely order from them. On the Edelbrock site, it shows two part numbers...One for 1-bolt and the other for a 3-bolt. Forgive my ignorance, but does it matter. Is one for OEm and the other a performance/aftermarket thing. To the best of my knowledge, the engine is original. Thanks again!
[Re: Sniper]
#2759972
04/04/20 03:04 PM
04/04/20 03:04 PM
RCKTMN
Massachussetts
Sniper, Thanks for the seconding on the bolt question.
[Re: elmor353]
#2760082
04/04/20 05:50 PM
04/04/20 05:50 PM
RapidRobert
I would get a 3 keyway timing chain set & put it on the advanced keyway (no exp w Cloyes but alot of complaints on em) and a parts house pump will work fine
[Re: RapidRobert]
#2760098
04/04/20 06:27 PM
04/04/20 06:27 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
I would get a 3 keyway timing chain set & put it on the advanced keyway (no exp w Cloyes but alot of complaints on em) and a parts house pump will work fine He specifically states he’s looking for OEM performance. Advancing the valve timing is a separate discussion.
[Re: Pacnorthcuda]
#2760171
04/04/20 09:20 PM
04/04/20 09:20 PM
RapidRobert
I would get a 3 keyway timing chain set & put it on the advanced keyway (no exp w Cloyes but alot of complaints on em) and a parts house pump will work fine He specifically states he’s looking for OEM performance. Advancing the valve timing is a separate discussion. Advancing the cam will work fine on this engine/easy to do/gains low end power, perfect for this app.
[Re: buildanother]
#2760274
04/05/20 08:54 AM
04/05/20 08:54 AM
RCKTMN
Massachussetts
Appreciate all the input. I was aware of the nylon teeth used by them to keep things quieter. The engine runs like a top. Luckily, the timing is solid. The only reason that I am looking into changing the timing chain is because my fan clutch went. Considering how it likely put a strain on the water pump, I am replacing that. With 109K on the engine (which I believe hasn't been opened up, yet), it seemed like good preventative medicine to do the timing chain now. I will definitely yank the motor out and check the pan if I notice that its timing chain's nylon teeth has deteriorated/fallen apart. Thanks again for all the suggestions/recommendations.
[Re: RCKTMN]
#2760291
04/05/20 09:40 AM
04/05/20 09:40 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Appreciate all the input. I was aware of the nylon teeth used by them to keep things quieter. The engine runs like a top. Luckily, the timing is solid. The only reason that I am looking into changing the timing chain is because my fan clutch went. Considering how it likely put a strain on the water pump, I am replacing that. With 109K on the engine (which I believe hasn't been opened up, yet), it seemed like good preventative medicine to do the timing chain now. I will definitely yank the motor out and check the pan if I notice that its timing chain's nylon teeth has deteriorated/fallen apart. Thanks again for all the suggestions/recommendations. Here's a pic from a low mileage 383, this is why to replace it now, they get old, they get brittle. I've seen at least two ads for Edelbrock timing sets that say by Cloyes? I dunno if it's a mistake or true, but the Edelbrock seems to be a lot cheaper than any of the Cloyes I saw. Additionally I didn't see any single bolt sprocket Cloyes, all three bolt sprockets.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Sniper]
#2760693
04/06/20 11:03 AM
04/06/20 11:03 AM
RCKTMN
Massachussetts
Sniper, I had not found the Cloyes info, but already had the Edelbrock. Thanks for the links.
