Front leaf upper shackle bushing(frame) #2756783
03/28/20 10:11 AM
03/28/20 10:11 AM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
I have an 88 w100, got some new leaves but I cant seem to tell if there are replacements for the frame side bushings on thr front leaf rear shackle would like to replace them at the same time. I have searched this on google but It has confused me even more. I'm tired of tripping over the springs and want to get these installed but need to get the upper bushings first. Does anyone know part numbers or sources for these? Thanks! up
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2756799
03/28/20 10:55 AM
03/28/20 10:55 AM
5thAve Offline
5thAve  Offline
Check the places that make poly bushings, they seem to be better at having bushings available for the different spots.
When I bought my new springs from a local shop they had a rack full of new bushings like how most shops have racks of nuts and bolts and they grabbed all the ones that you'd want to replace when it's apart.
Re: Front leaf upper shackle bushing(frame) [Re: 5thAve] #2756827
03/28/20 11:56 AM
03/28/20 11:56 AM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
I checked energy suspension, prothane. I couldn't find a listing for it. shruggy
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2756850
03/28/20 01:13 PM
03/28/20 01:13 PM
Alberta
440_Offroader Offline
Alberta
You could always go with these. I've put these on a couple 4x4s.
https://ramchargercentral.com/jungleshddodgecomponents/front-spring-hd-frame-bushing-kits/
Re: Front leaf upper shackle bushing(frame) [Re: 440_Offroader] #2756903
03/28/20 02:55 PM
03/28/20 02:55 PM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
Thanks for the info but I was hoping to replace the bushings...Is that correct that that kit is 307+$ shock
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2757095
03/29/20 07:36 AM
03/29/20 07:36 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I agree with 5thAve, local sprimg shop can help. Also if price and or availability is an issue some chevy bushings can work. I did this for the rear shackles on my LRE. Very similar.
Re: Front leaf upper shackle bushing(frame) [Re: redraptor] #2757130
03/29/20 10:12 AM
03/29/20 10:12 AM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
I guess then then consensus is there is no replacement bushing available to the general public for these trucks and I'll have to do what I was afraid of tear it down then wonder around to spring shops (none local) to find a rubber bushing (which I am sure aren't custom made for them).
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2757197
03/29/20 12:37 PM
03/29/20 12:37 PM
Alberta
Alberta
When you have them out, measure up the dimensions. There has to be something that would fit. You would think, dodge would have used the same size bushings in other applications. There are many generic bushing sizes out there as well.
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2757199
03/29/20 12:47 PM
03/29/20 12:47 PM
Fitchburg, WI
BIGHOOK Offline
BIGHOOK  Offline
Fitchburg, WI
You could try the local Dodge Dealer. Some first gen parts are surprising still available.
Or these guys: https://www.lmctruck.com/1972-93-dodge/suspension-front-rear/dc-1972-93-front-suspension-4wd
Re: Front leaf upper shackle bushing(frame) [Re: BIGHOOK] #2758180
03/31/20 09:41 PM
03/31/20 09:41 PM
Id
mopeman Online content
mopeman  Online Content
Id
Yup, call around to the spring shops. If my local guys can get the bushings for my '75 D600, they can get them for a W100.
My local (45 miles away) spring shop is Boise Spring Works 208-377-1157 or 800-585-5332.
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Front leaf upper shackle bushing(frame) [Re: mopeman] #2758186
03/31/20 09:59 PM
03/31/20 09:59 PM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
I did what I didn't want to do, but they actually looked ok, so I left them untouched.
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2758426
04/01/20 02:36 PM
04/01/20 02:36 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
part number is 2653700
I have 4 of these trucks and while you can fit some poly energy suspension type bushings in the old hole once the sleeve is removed, there is nothing like the factory bushings availalbe.
Re: Front leaf upper shackle bushing(frame) [Re: jerseybud] #2758827
04/02/20 12:04 PM
04/02/20 12:04 PM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
Thanks...so they are n/a.
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2759292
04/03/20 08:52 AM
04/03/20 08:52 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
those Jungle's hangers are worth it.
I have is front leaf spring hanger shackle kit and both of his rear leaf spring hangers with rear shackle flip on a 74 Ramcharger using 56" springs in the rear.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Front leaf upper shackle bushing(frame) [Re: mopeman] #2764586
04/16/20 12:10 PM
04/16/20 12:10 PM
Apollo, PA.
B1MAXX Offline OP
B1MAXX  Offline OP
Apollo, PA.
just an update... This truck drives so much better now up I would have never thought that new front leaf springs would have done this much to stop the front end wander.
Re: Front leaf upper shackle bushing(frame) [Re: B1MAXX] #2764907
04/17/20 07:03 AM
04/17/20 07:03 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Cool! dakota
