New spring perches, larger hole size #2757714
03/30/20 07:15 PM
03/30/20 07:15 PM
USA
Suregrip391 Online content OP
Suregrip391  Online Content OP
USA
Is it important to get a new spring pin to match the larger hole that comes on new spring perches? Someone told me that it’s not necessary because it’s the u-bolts that place the rear where it needs to be and don’t worry about it. Bolt er’ in and forget about it.
Thoughts?
Re: New spring perches, larger hole size [Re: Suregrip391] #2757732
03/30/20 07:51 PM
03/30/20 07:51 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I just went through this on my Dart. I like them to be centered. I cut a couple spacers out of 3/8 pipe, I think it was. Got lucky as it fit great over the pin and in the hole. They centered the perches up on the springs.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: New spring perches, larger hole size [Re: Suregrip391] #2757735
03/30/20 08:00 PM
03/30/20 08:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
How big is the hole??
Re: New spring perches, larger hole size [Re: mopars4ever] #2757755
03/30/20 08:24 PM
03/30/20 08:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd want to drop the rearend on there, bolt it up, measure the wheelbase.
Get that right & equal both sides.
If the holes are concentric, I'd want to sleeve the locating pins for race use so the axle can't re-locate itself.
If not concentric, double-check measurements, break out a die grinder & bit, make them concentric, and sleeve 'em.
For street use, sleeving is probably not necessary, depends on power/shock loads/grip.
Re: New spring perches, larger hole size [Re: topside] #2757765
03/30/20 08:36 PM
03/30/20 08:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I bought the next size up bolt with a larger head to fill the hole in the spring pads, and then had to drill out the register holes in the springs to fit the bigger bolt diameter. Spring steel does not drill very fast!
Re: New spring perches, larger hole size [Re: Neil] #2757831
03/31/20 12:11 AM
03/31/20 12:11 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
So who is reinventing the wheel??? We been stickin it in the same hole for over 50 years tsk whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New spring perches, larger hole size [Re: hemi-itis] #2757836
03/31/20 12:29 AM
03/31/20 12:29 AM
moparmarks Offline
moparmarks  Offline
Seems some of the replacement perches have a larger hole. I have inboard springs with new perches. There was a lot of slop. I wanted it all centered up so it didn't go down the road sideways like an old Chevy truck.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: New spring perches, larger hole size [Re: mopars4ever] #2757839
03/31/20 12:31 AM
03/31/20 12:31 AM
moparmarks Offline
moparmarks  Offline
Mine were like 1/2"
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: New spring perches, larger hole size [Re: moparmarks] #2757854
03/31/20 01:30 AM
03/31/20 01:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would push or pull the rear end perches forward to get the most traction on it I could get with them up twocents work
Re: New spring perches, larger hole size [Re: moparmarks] #2757969
03/31/20 12:15 PM
03/31/20 12:15 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Yup, that’s what I do on all the street car rears I narrow, you can buy the tubing by the foot and just tack weld a 3/4 “ on inside of perch. Moroso or Competition Engineering make em with 1/2” hole, but they used to be spendy. That is by far the quickest and most cost effective way to do it. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: New spring perches, larger hole size [Re: hemi-itis] #2758000
03/31/20 01:13 PM
03/31/20 01:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I bought new springs from Eaton and the register bolt was smaller than the stock one for some reason. I just went up a bolt size and drilled the holes in each leaf bigger.
Aftermarket parts always have to have at least one thing not quite right about them.
Re: New spring perches, larger hole size [Re: Neil] #2758074
03/31/20 04:54 PM
03/31/20 04:54 PM
USA
USA
Thanks guys. I think I’ll try the 3/8 black pipe trick to keep things in line. Makes you wonder why something as simple as a hole can’t be made right after all these years. Always something.
Re: New spring perches, larger hole size [Re: Suregrip391] #2758082
03/31/20 05:14 PM
03/31/20 05:14 PM
BDW Offline
BDW  Offline
I don’t understand the concern?
Once the U-bolts are tightened, where’s it going to go?
I highly doubt the 1/16” is going to make a difference.
Re: New spring perches, larger hole size [Re: BDW] #2758091
03/31/20 05:40 PM
03/31/20 05:40 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Re: New spring perches, larger hole size [Re: Suregrip391] #2758096
03/31/20 05:55 PM
03/31/20 05:55 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
The nut on the bottom of the leaf spring pin will/should center itself to the mounting plate.
Re: New spring perches, larger hole size [Re: UCUDANT] #2758296
04/01/20 08:28 AM
04/01/20 08:28 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Originally Posted by UCUDANT
I stopped buying the Mopar perches and switched to the Moroso for that reason. On the several spring, and axle swaps I have done I have never once had the Mopar perch sized centering pin. It hasn't mattered if the springs were stock 30yr old or brand new aftermarket, the locating pin has always been the smaller diameter.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: New spring perches, larger hole size [Re: hp383] #2758350
04/01/20 11:22 AM
04/01/20 11:22 AM
moparmarks Offline
moparmarks  Offline
Those Mopar perches look like they are for the 73-up B Isolation setup.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: New spring perches, larger hole size [Re: BANDIT] #2759078
04/02/20 07:14 PM
04/02/20 07:14 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi , the P4120074 mopar spring seats have a .625 or 5/8" center hole . the ones you want are mopar P5007857 with the .500 or 1/2" center hole . wave drive ronnie
Re: New spring perches, larger hole size [Re: 1969ronnie] #2762830
04/11/20 07:46 PM
04/11/20 07:46 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The bigger hole perches from Mopar are from their truck parts bin, resold as Performance Parts.
I love the cut pipe spacer idea. Why build a car and allow the rear housing not to be accurately located? No wonder some of the Mopars out there are crapboxes.
As much precision that can be controlled by me, gets the go ahead.
Re: New spring perches, larger hole size [Re: Magnum] #2762934
04/12/20 08:17 AM
04/12/20 08:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The large hole perches are for the isolator type attachment. They are later production, therefore probably more common. I've been using the 3/8" pipe as a spacer for years.
Doug
