Line Lock (again)
#2757138
03/29/20 10:24 AM
03/29/20 10:24 AM
Posts: 1,001 Canada
Ghoste
Canada
I know the question has been asked dozens of times but there doesn't seem to be a lot of consensus on it. Here is what I have. 69 B-body, big block, manual transmission. Power brakes with disc front. Brake lines go from the master cylinder to a distribution block which houses the safety switch for the warning light. From that block there is a line which goes to the rear. Before getting to the rear brakes there is a holdoff valve or proportioning valve as some call it. The other side of my distribution block has a single line which goes up to a metering valve and the metering valve then has two lines which feed the front brakes. I was going to plumb the line lock in the line between the distribution block and the metering valve but some tell me thats bad. My other option is to plumb it between the distribution block and the holdoff valve, but some say thats bad. Still others say after the holdoff valve with some saying never do that. In short, every version has someone who says it works and someone who says never do that. I want to hold the front brakes on without screwing up the oem valves. Is there someone with a manual transmission car who wants just front brakes on who has the SAME three valve system as me who has a working line lock in their car? If you do where did you put it and what ports did you use on the lock? Also I dont want to take any of the three valves out of the system.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Line Lock (again)
[Re: Ghoste]
#2757139
03/29/20 10:27 AM
03/29/20 10:27 AM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
I replied on DC.COM to this, it needs to go after the switching valve, simple
[Re: CSK]
#2757144
03/29/20 10:43 AM
03/29/20 10:43 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
My 65 swapped to frt disc and line loc.I have mine mounted by the master and going to rears Its plumbed before the PP valve.Has been there for like 15 years and no problems.Rocky
Chrysler Firepower
[Re: Stanton]
#2757289
03/29/20 04:08 PM
03/29/20 04:08 PM
Posts: 1,001 Canada
Ghoste
Canada
So I can put it between the distribution block and the metering valve and I am good to go.
[Re: therocks]
#2757313
03/29/20 05:23 PM
03/29/20 05:23 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
My 65 swapped to frt disc and line loc.I have mine mounted by the master and going to rears Its plumbed before the PP valve.Has been there for like 15 years and no problems.Rocky NHRA outlaw using the line lock on the rear brakes years ago, I'm sure it is still illegal to use it that way OP, if you install it in the brake line between the master cylinder and the brake warning switch the brake warning light will come on when you have the line lock working, which is one way of knowing it is working I've plumed more than one car that way, most people like it
[Re: Cab_Burge]
#2757505
03/30/20 09:22 AM
03/30/20 09:22 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
here's another really neat setup
[Re: SportF]
#2757899
03/31/20 09:20 AM
03/31/20 09:20 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
There is some nice looking installs there, but isn't the point of installing a dual master to have redundant brakes? And if you don't have that factory type shuttle valve in there, you don't.
??? Nothing gets removed to install a lineloc ! Also, the reservoirs are dedicated to front or rear.
[Re: Stanton]
#2758007
03/31/20 01:48 PM
03/31/20 01:48 PM
Posts: 1,213 Minn
SportF
Minn
My point was, looking at the pictures, when you see a nice clean install, but no shuttle valve, you don't have redundant brakes.
This has come up many times before, but to prove you don't have "safety brakes" without a shuttle valve, all you gotta do is go out to your car, open a bleeder, and stomp on the brakes. The pedal will go to the floor.
If you are going to the trouble of installing a dual cylinder, go all the way. That is what I am saying. Stirring up the pot I guess, sorry.
[Re: SportF]
#2758070
03/31/20 04:50 PM
03/31/20 04:50 PM
Posts: 1,841 South Bend
John Brown
South Bend
If you are going to the trouble of installing a dual cylinder, go all the way. That is what I am saying. Stirring up the pot I guess, sorry. Are we to assume you have personally done that test yourself?
[Re: SportF]
#2758123
03/31/20 07:17 PM
03/31/20 07:17 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I put a dual 68 Ply master on a street rod. When a front cylinder leaked I was surprised to find the pedal going to the floor. After a small amount of research, the answer was there.
Its a real simple test, nobody wants to do it as they have believed for so long.....not unlike myself.
Best of luck to you. Not trying to be a wise guy but I have done just the opposite. I put a dual M/C on my 63 from a 68 B-body and I can open a bleeder in the front or rear and still have about half my brake pedal. Don't know why you did not because it is two separate systems. All the combination valve is for is to push a piston over to turn the brake lite on to warn the driver if one side looses fluid/pressure which I don't have in mine and the later combination valves also have the prop and metering valve in them. Like I say I don't mean to sound like a wise guy or dought your word as I can only say that I have done a few cars like my 63 and always still have brakes if one side gets a leak. Course its not a great pedal but it still has a 1/4 to maybe half pedal and still stops the car but only on one axle of course. Ron
[Re: SportF]
#2758124
03/31/20 07:19 PM
03/31/20 07:19 PM
Cab_Burge
Baloney sauce Go look at any race car with dual master cylinders with no "shuttle valve" Mine works fine, my new race car will have dual master cylinders with no shuttle valve or the fitting for it also
[Re: 383man]
#2758135
03/31/20 07:54 PM
03/31/20 07:54 PM
Posts: 6,290 nowhere
Sniper
nowhere
All the combination valve is for is to push a piston over to turn the brake lite on to warn the driver if one side looses fluid/pressure No, that is not all the combination valve does. The valve that lights up the warning light also closes off the leaky half of the system keeping a firmer pedal than otherwise. The combination valve also provides metering, proportioning and functions as a splitter. I'm pretty sure if none of that was needed then none of the factory engineers wouldn't have put it in there, notice how they all did it. I think I'll listen to the engineers.
[Re: SportF]
#2758143
03/31/20 08:37 PM
03/31/20 08:37 PM
John Brown
South Bend
Oh, it will work fine, great actually. But if you lost a line, the pedal will go to the floor.
Hey, here is a really easy test, put the line lock on, then press the brake pedal. Try that and report back to us what happens. I put a line lock on the front brake side and completely removed the combination block that contains the warning switch. When I hold the line lock button down and lock the front brakes, the brake pedal gets hard as a rock with only the back brakes being actuated by the brake pedal. Pedal doesn't go to the floor. If anything, my pedal stays up higher. My 67 Caprice must be different than a street rod.
[Re: John Brown]
#2758152
03/31/20 08:58 PM
03/31/20 08:58 PM
Posts: 1,213 Minn
SportF
Minn
So with the line lock blocking that front brake line, and the line being already filled with fluid, there would be zero piston movement for the front brakes, yet the pedal moved enough to apply the back brakes.
That is because the flow of those two lines is connected internally, and they have to be. If there was no internal flow/connection, the pedal wouldn't move enough to apply the back brakes. This also means if there was a leak in that front line, or the rear line, the pedal would go all the way to the floor.
As state above, the switch valve shuttles to the leaking (low pressure) side to cut off flow down stream from the valve, allowing all master flow to go to the non leaking side.
This topic comes up from time to time, I'm just trying to inform folks they ain't as safe as they think they are. But, no one will open a bleeder to test, so this post will end like all the others.
Stay safe, hope for better days ahead, and a spring with a racing season to it..
Edit: It just occurred to me that most all of us have already tested this thing as I wanted to. You change out your rear, or something on the front end and you gotta bleed the brakes. So, with a guy on the bleeder, you push on the pedal and it goes to the floor, eh? You floor it a couple times, refill the master and you got it. BUT, the pedal went to the floor! Would it do that IF you had redundancy?
[so was it Billy Mays that said this??]---BUT WAIT, THERES MORE! Even if you have a shuttle valve the pedal will go to the floor when bleeding, what's up with that? That's because when you are bleeding you aren't pushing hard enough to overcome the centering springs on the shuttle valve, SOO, you only have redundancy when you press on the brakes like you are stopping the car.
OK I'm done, wish I could take my car out and my sweetie to the restaurant. Stay safe.
