Its one of those what fluid to use for power steering posts
#2756569
03/27/20 06:02 PM
03/27/20 06:02 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I don't have an owner's manual for the 91 Ramcharger, I'm looking for the recommended fluid to use in the power steering.
My 92 Dakota says ATF, but it is rack and pinion.
I've used ATF in other 1st gen and older Mopars, but this is going to be a new steering box, pump, and lines, so I figured since I'm starting from scratch I may as well use what it called for.
It's primarily a winter and crappy weather beater, so the best flowing fluid for cold weather is best option.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Its one of those what fluid to use for power steering posts
[Re: gtx6970]
#2756577
03/27/20 06:13 PM
03/27/20 06:13 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
It would help if we knew what year, make, model, and engine size??
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2756578
03/27/20 06:17 PM
03/27/20 06:17 PM
hp383
State of Confusion
It would help if we knew what year, make, model, and engine size?? Updated, 91 Ramcharger. Engine is 318 if thats of importance for some reason.
[Re: hp383]
#2756580
03/27/20 06:22 PM
03/27/20 06:22 PM
Dartsport540
Ringtown, Pa.
Identifix/ Direct hit, which uses mopars Factory info. Lists Mopar P/N 04883077 (MS-5931) Power steering fluid.
[Re: Dartsport540]
#2756583
03/27/20 06:26 PM
03/27/20 06:26 PM
Dartsport540
Ringtown, Pa.
I am not at my business right now. But I would have to check on my Power Steering fluid bottle and my Synthetic ATF fluid paper work. They both have a list of the specs or fluid specs that they cover. I could check tomorrow morning, and post back here.
[Re: Dartsport540]
#2756586
03/27/20 06:45 PM
03/27/20 06:45 PM
hp383
State of Confusion
I am not at my business right now. But I would have to check on my Power Steering fluid bottle and my Synthetic ATF fluid paper work. They both have a list of the specs or fluid specs that they cover. I could check tomorrow morning, and post back here. That would be great. The truck goes under the knife early next week.
[Re: volaredon]
#2756770
03/28/20 09:48 AM
03/28/20 09:48 AM
Dartsport540
Ringtown, Pa.
Suppose to be power steering fluid that meets Mopar SPEC # 5931 .. Going to have to look on the back of some power steering fluids available in your area...
[Re: Dartsport540]
#2756789
03/28/20 10:37 AM
03/28/20 10:37 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Mopar had Power Steering Fluid for years
But when the ATF improved to ATF +4 most of the old parts numbers for PS fluid superseded to that
So your 91 Ramcharger would work fine with either
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: dOc !]
#2758294
04/01/20 08:21 AM
04/01/20 08:21 AM
hp383
State of Confusion
Thanks all.
I got the steering box, hoses, lines, etc. changed yesterday, and the system now has fresh power steering fluid.
[Re: mopars4ever]
#2758304
04/01/20 09:04 AM
04/01/20 09:04 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Mopars with Saginaw pumps and 72-93 trucks which have Saginaw boxes the GM cold weather P/S fluid works great. Gets rid of that whine they get with regular p/s fluid.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
