3rd gen Dakota front coil spring interchange?
#2756395
03/27/20 08:00 AM
03/27/20 08:00 AM
Posts: 8,674 Buford, GA
I_bleed_MOPAR
Buford, GA
Finishing up 5.9 swap into the Dakota and obviously need to swap the front coils as the nose is very low due to it being a V6 truck. My question is will 1st gen 2wd Durango coils work since they are more plentiful in the pullaparts? Checking different part #s at RA shows very little interchange and that a 4.7 is different than a 5.2/5.9, I'm guessing since the 4.7 is lighter. Anyone have some input?
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: 3rd gen Dakota front coil spring interchange?
[Re: AAR-B4]
#2756978
03/28/20 06:56 PM
03/28/20 06:56 PM
I_bleed_MOPAR
Buford, GA
Thanks but I want to raise it, not lower it. PO had put on lowering blocks in the rear and those are coming off in the near future. Tim
