1987 2.2 with 5 speed tranny removal #2756174
03/26/20 12:43 PM
03/26/20 12:43 PM
Escondido, California
JonGottaDemonDad Offline OP
Moparts,
I am trying to remove the transmission on this 87 horizon to change the clutch on it. There is a bolt-on the back of the transmission I can find no way to remove it. I gave up last fall and ready to pull it out and finish it in April.
If I remember right the exhaust is in the way. Any advice for me?
Thanks,
Craig
Re: 1987 2.2 with 5 speed tranny removal [Re: JonGottaDemonDad] #2756177
03/26/20 12:53 PM
03/26/20 12:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you looked online for a how to on that job. Sometimes they have ways of making it easier.
Re: 1987 2.2 with 5 speed tranny removal [Re: stumpy] #2756188
03/26/20 01:23 PM
03/26/20 01:23 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't know about a Horizon but I've pulled a 2.2 turbo out of an '85 Daytona with the five speed and a 2.2 out of a '93 Shadow with the automatic and left the transaxle in the car both times. I can't recall a bolt not being accessible.
Re: 1987 2.2 with 5 speed tranny removal [Re: JonGottaDemonDad] #2756201
03/26/20 02:41 PM
03/26/20 02:41 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Probably the same as my '83 Shelby Charger. That means it's a giant PITA. Personally, if I had to do one again, I would drop the engine and transmission out the bottom, swap the clutch on a sheet of wood, reattach the trans, then hoist them both back in. You can get an engine support with a screw jack pretty cheaply. I used one of those to drop the engine and trans out of a Shadow. Last time I had an L-body clutch, I gave up on it and took it to the dealership. It took them at least three times book time to do it. Afterward, the mechanic asked me to never bring the car back. Dropping everything out the bottom, in my mind, would be easier in the long run for the home game. It's tight under there with the 5-speed.
Re: 1987 2.2 with 5 speed tranny removal [Re: JonGottaDemonDad] #2756202
03/26/20 02:43 PM
03/26/20 02:43 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Originally Posted by JonGottaDemonDad
Moparts,
If I remember right the exhaust is in the way. Any advice for me? Thanks, Craig
I am doing a memory search but can not think of what bolt you are talking about. I have removed the A-525, A-520, A-523 and A555's out of so many 1981-1994 2.2/2.5 cars.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 1987 2.2 with 5 speed tranny removal [Re: stumpy] #2756225
03/26/20 04:07 PM
03/26/20 04:07 PM
I wish I bought a Clintons manual.
Re: 1987 2.2 with 5 speed tranny removal [Re: JonGottaDemonDad] #2756234
03/26/20 04:41 PM
03/26/20 04:41 PM
Kirkland, Washington
Pacnorthcuda Offline
Those just tell you to make people who know too much disappear, and make it look like an accident.
Re: 1987 2.2 with 5 speed tranny removal [Re: Pacnorthcuda] #2756240
03/26/20 05:03 PM
03/26/20 05:03 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Urrrr.... Remove the obstruction you stated, the exhaust.
But I second the out the bottom deal, far easier.
Dont let a 2.2 combo get the best of you, them cars are very simplistic. If you can wrench on any older mopar your up to the challenge.
I looked on you tube briefly and thats a bit old it seems to find a vid, but I forget the trans #
STOP POTATO HATE!
Re: 1987 2.2 with 5 speed tranny removal [Re: JonGottaDemonDad] #2756254
03/26/20 06:05 PM
03/26/20 06:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Never one of those manuals. Get these best money you can spend. Manual
Re: 1987 2.2 with 5 speed tranny removal [Re: NITROUSN] #2756284
03/26/20 08:31 PM
03/26/20 08:31 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
After removing the shift linkage, the half shafts, the speedo cable and the wiring plug for the backup lights the rest is bolts. Besides the bellhousing bolts, there are the left trans mount bracket (3), the rear bobble strut bolt and bracket. That should be it. So please shoot a picture of the bolt.
65 Formula S Cuda
Re: 1987 2.2 with 5 speed tranny removal [Re: Dave_J] #2756292
03/26/20 09:19 PM
03/26/20 09:19 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
As I recall one of the starter bolts comes in from the engine side. Long extension is how I got to it. I can tell you that it is easier to get the trans out and back in if you remove the crossmember under the steering rack. That's also a good time to clean it up with some degreaser.
Re: 1987 2.2 with 5 speed tranny removal [Re: Dave_J] #2756294
03/26/20 09:33 PM
03/26/20 09:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What year did they put the 3rd bolt on the starter you had to go in above the starter with a short socket and a long extension? If I remember it correctly, a 18" long extension (a couple shorter extensions will work, but not as well as a single long one) will get you past the exhaust pipe so you can use a ratchet. Without the long extension, the ratchet ends up right at the exhaust pipe and there isn't enough room to swing the ratchet.
That starter bolt uses the same socket as the two on the front. I suggest you put at least one of the front bolts back in the starter to hold it in place until you have the back bolt out, or the starter may fall and hit you on the head. Once all the bolts are out, the starters tend to fall right out, but you need to turn it just right to get the wires off the starter, then you need to twist it just right to get it out of the hole. I was always amazed the starter would fall out, but once you removed the wires, you have to flip it a dozen different way to get it out of the hole its in.
Good luck. Gene
Re: 1987 2.2 with 5 speed tranny removal [Re: Dave_J] #2756317
03/26/20 10:27 PM
03/26/20 10:27 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Same here.
I cant think of any bolt issue . Although its been a while since Ive had one of them apart , like quite a while
But I do seem to remember something about the starter having a bolt on the back side
Re: 1987 2.2 with 5 speed tranny removal [Re: gtx6970] #2756375
03/27/20 12:53 AM
03/27/20 12:53 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Originally Posted by gtx6970
Same here.
Out of the 10 or so of these trans I have R&R more than half were missing that starter bolt.
There is also a steel brace that goes from the belhousing to the rear of the block. It has two bolts in both ends and an aluminum adapter that a starter bolt goes into.
This may be "Refer to TurboMopar or MiniMopar" forums. If the weather was good or if I had room in the garage I'd pull the 84 Rampage around and put it up on stands and take a peek at its a525. The 1984's are not much different than the 1994's, few things but basically the same.
65 Formula S Cuda
Re: 1987 2.2 with 5 speed tranny removal [Re: Dave_J] #2756378
03/27/20 01:08 AM
03/27/20 01:08 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
When I did a few of these I also did a refresh of the Rack&Pinion, new inner tie rod grease and boots. So like said above I would remove the exhaust, drop the lower balljoints, remove the Steering shaft bolt and drop the K frame out. Soooo much more room.
Sometimes I'd pull the trans and drop the oil pan too. A oil pump is easy to replace as most of these cars had 150+K miles and a $15 oil pump was cheap insurance. My 2.5's got the balance shaft removed.
65 Formula S Cuda
Re: 1987 2.2 with 5 speed tranny removal [Re: Dave_J] #2756507
03/27/20 02:39 PM
03/27/20 02:39 PM
I have to fix the shifter linkage as well. I am converting from the stock plastic to a Heim joint while it is apart.
I am going to get it out this weekend and snap a photo.
Craig
Re: 1987 2.2 with 5 speed tranny removal [Re: JonGottaDemonDad] #2756600
03/27/20 07:20 PM
03/27/20 07:20 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Those factory plastic shift linkage ends just degrade from proximity to all that exhaust heat, ozone, and just age. Converting mine to heim joints was one of the best mods I ever did. I was tired of having to open the hood and reach down into the hot engine compartment and pop the shift rod back on. Then again, I drove mine quite hard. I went through three transmissions in the 34 years I owned it. Two in the first 5 years.
