Re: 833 popping out of 4th
[Re: 440newport]
#2755842
03/25/20 02:18 PM
03/25/20 02:18 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I have '68 A body 4 speed in my Mirada the last few years. Last summer it started popping out of forth occasionaly only on decelleration and has gradually gotten worse. It isn't quite so bad when the trans is warmed up though.
From what I've read this is likely caused by the center bore of bellhousing being out of alignment with the crank. (I didnt check it for run out at the time, just put it together) WHich may put the input shaft at a slight angle causing wear on the engagement teeth for 4th on the input shaft and/or 3-4 shift collar.
I plan to pull the gearbox and check and fix the bellhosuing alignment if necessary. My question is it likely I'll need parts in the gearbox too? input shaft etc? ANy other thoughts on what it could be? I checked the shift rods alignemnt and it seemed fine, I even tried adding a little more length on the 4th gear shift by taking some from 3rd. but it didn't make a difference that I could tell. What I have seen when they are way off is the end of the output shaft wears where the needles ride, the needles, the input bearing, and if ran long enough the input gear and cluster gear polish up pretty good too. You will also see a heavy polish where the pilot bearing rides. A trans that is dialed in looks like new at the pilot bearing. It used to be a big problem with blowproof bells, and early hemi swaps.
[Re: 4406bbl]
#2755866
03/25/20 03:05 PM
03/25/20 03:05 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
How is the shifter linkage, sloppy? Have you tried adjusting it? Before you pull the trans I would try that.
[Re: 440newport]
#2755972
03/25/20 06:11 PM
03/25/20 06:11 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Now I'm NOT an engine/trans guy BUT back in 1976-77 my old 340 Cuda 4-speed was doing this. I had a trans guy go through it & said it was the synchros.
[Re: fourgearsavoy]
#2756070
03/26/20 12:19 AM
03/26/20 12:19 AM
Posts: 5,163 CT
GTX MATT
CT
Most common cause is worn clutching teeth on the 4th (input shaft) and the 3-4 slider. I would first check the obvious shifter linkage adjustments but if it goes in solid but pops out as soon as you let of the gas it probably needs a new input and slider Gus This, if the shifter is correctly adjusted the dog teeth are most likely worn.
[Re: fourgearsavoy]
#2756143
03/26/20 10:59 AM
03/26/20 10:59 AM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Most common cause is worn clutching teeth on the 4th (input shaft) and the 3-4 slider. I would first check the obvious shifter linkage adjustments but if it goes in solid but pops out as soon as you let of the gas it probably needs a new input and slider Gus I agree
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: fourgearsavoy]
#2756165
03/26/20 12:01 PM
03/26/20 12:01 PM
Posts: 674 Kennewick, Wa.
71vert340
Kennewick, Wa.
Most common cause is worn clutching teeth on the 4th (input shaft) and the 3-4 slider. I would first check the obvious shifter linkage adjustments but if it goes in solid but pops out as soon as you let of the gas it probably needs a new input and slider Gus I have a photo to back this up. My transmission (in my 71 Challenger) kept popping out of 4th and I finally got it into my mechanic and this is what he found. I was fortunate in that it didn't damage the trans case but it did require an entire rebuild because of all the metal in the tranny. In my photo, you can see the teeth were wearing against the case when the input shaft was shoved forward. I don't remember all the details as this happened in 1973-74. It cost me almost $200 back then. I now have a great clutch alignment tool though. Get it taken care of as soon as possible. Note on the gear teeth how it was rolling over the edge of the teeth. It is cut back into the gear about 1/4". Terry
[Re: dragon slayer]
#2818319
09/07/20 08:30 PM
09/07/20 08:30 PM
Posts: 4,588 St. John's Newfoundland
440newport
Just to update on this... A few weeks back I jack the car up to pull the gearbox out and see whats going on. After I pull the driveshaft I look up and see one of the trans to bellhousing bolts is missing, and the others are loose. There was almost a 1/4" gap opened up between the bell and trans. I find another 7/16" bolt, tighten them up, stick the driveshaft back in and test drive it. No more popping out of forth. I should have checked but it didnt even occur to me that it would be something like that. Now I'm sure the input shaft being at an angle like that didn't do anything any good, but I've been driving it since then a lot and it seems fine so far.
