94 Dakota v6 to v8 swap (problem)
#2749890
03/07/20 02:59 PM
03/07/20 02:59 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Help needed. Swapped a 97 360 magnum into my 94 v6 Dakota. All is good except one major issue, the engine is about 2 inches too far forward. I do not see a set of holes in the frame crossmember that allows movement of the frame mounts. My research said this would be a simple swap Has anyone encountered this issue??
Re: 94 Dakota v6 to v8 swap (problem)
[Re: AAR-B4]
#2749964
03/07/20 08:18 PM
03/07/20 08:18 PM
Guitar Jones
The trans mount to crossmember bolts and/or mount bracket should be slotted. None of that changes from a V6 to a V8. Did you use the V6 or V8 engine mounts? The 94 may not be the same as the 97. In other words you may need 94 V8 mounts.
[Re: Guitar Jones]
#2749970
03/07/20 08:38 PM
03/07/20 08:38 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Some background, The engine and driveline (97 5.9 , sb 727, drive shaft and 8 3/4) were removed from a 88 single cab short bed using the Shumacher mounts (LA mounts). Going into 94 3.9 42RH single cab short bed. Used 94 5.2 mounts (5.9 not available in 94) anchor brand #2652 (same for v6 or v8). Its 2wd, should be easy. When I lowered the motor into the frame it looked too far forward (water pump is too close the radiator for a conventional fan. I went ahead with the trans (727) and its 2 " from reaching the crossmember. The drive shaft is the same amount short. I'm stumped.........
[Re: stumpy]
#2750000
03/07/20 10:56 PM
03/07/20 10:56 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
I don't know either so I did a google search and came across this thread on another forum. Maybe has something to do with your problem? Linky >> 3.9 to 5.9
John
[Re: AAR-B4]
#2754633
03/22/20 04:52 PM
03/22/20 04:52 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
I have a 91 Dakota sport that was a factory v8 truck. I am using a 2000 5.9 magnum engine and 904 transmission. Unless you will be using the factory overdrive transmission. Shumocker makes a transmission mount adapter for the 3 speed transmission.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#2754640
03/22/20 05:02 PM
03/22/20 05:02 PM
mopar65
Picture of transmission mount
support our troops
[Re: mopar65]
#2754760
03/22/20 08:59 PM
03/22/20 08:59 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
I don't know if this is relevant info or not, but I discovered a couple years ago the Dodge used 3 different transmission mounts between 1992 and 1994 Dakotas. The 93 was a changeover year, and neither the 92 nor the 94 will work without modification, and the 93 mounts are no longer available. The truck I ran into this on was a 4x4, but I've heard they did the same thing on the 2x Dakotas. I had to modify the crossmember to get the 94+ trans mount to work. Maybe you have the wrong crossmember for the mount you are trying to use?
I sure hope you guy get this figured out, I will be putting a 96 318 4x4 drive train on a 91 4x4 chassis soon, and will be covering this with 49 Dodge sheetmetal. I'll have enough to deal with making the sheet metal work, I don't want to have to deal with a motor/trans issue as well, but I will if I need to. Gene.
[Re: poorboy]
#2754826
03/22/20 11:42 PM
03/22/20 11:42 PM
mopar65
I sure hope you guy get this figured out, I will be putting a 96 318 4x4 drive train on a 91 4x4 chassis soon, and will be covering this with 49 Dodge sheetmetal. I'll have enough to deal with making the sheet metal work, I don't want to have to deal with a motor/trans issue as well, but I will if I need to. Gene. I cant speak about a 4x4 truck. But my 91 was v8 with a A500 over drive transmission. With the magnum 360 and 904 transmission. Using the adapter mount. My engine/ transmission bolted right in with no problems
support our troops
[Re: AAR-B4]
#2755328
03/24/20 08:19 AM
03/24/20 08:19 AM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
Very strange. All the extra length is forward of the mounts on a V8. Apples and oranges probably but I'm wrapping up my swap of a 5.9 into a 3.9 QC. I used the V6 mounts with the only problem being I had to trim some of the plate off the bottom to clear the oil pan lip. I did have the mounts reversed L to R and they were several inches off. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: AAR-B4]
#2768193
04/25/20 05:45 PM
04/25/20 05:45 PM
mopar65
The engine is in. To recap; it's a 94 2wd v6 Dakota that I am swapping to a 97 5.9 magnum and 727. I had to drill and tap a 1/2" plate for each side to move the motor mount forward about 2" (different for each side). Sandwiched the plate between the block and the mount. All I can figure is the brackets on the k-frame are different from v6 to v8. Moral of the story: don't believe anything you read on the net and only half of what you see. Other sites (not this one) said this was a "easy swap" "uses same mounts". BTW the trans mount used is the one like 2 posts above. can you post some pics of your mounts? Something doesn't sound right. I sold the V6 mounts , the frame mounts off my 87 parts dakota to a guy so he could install a v8 in his 94/95 dakota. But he was going from a 4 cylinder truck.
support our troops
