1966 nascar charger #2755142
03/23/20 05:51 PM
03/23/20 05:51 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
a friend of a friend has a 66 charger 426 hemi factory nascar version with the 3 piece rear spoiler . looking for someone that can verify it.
ted
5549 post on old board
Re: 1966 nascar charger [Re: 05dakota] #2755181
03/23/20 07:36 PM
03/23/20 07:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You mean the spoiler or the car ?
The story goes that spoiler was homologated w/NASCAR so they could be used on the cars.
The spoiler would have a part #, but I'd doubt they were assembly-line-installed.
As for the cars, by that time the competitive builders were cutting them up from shells and a lot of fab work was done.
They weren't quite "panel cars" then, but were significantly modified, and not very streetable, likely no VINs.
Re: 1966 nascar charger [Re: topside] #2755222
03/23/20 09:19 PM
03/23/20 09:19 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think those spoilers were reproduced for a while so... work
Re: 1966 nascar charger [Re: bobby66] #2755241
03/23/20 09:55 PM
03/23/20 09:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: 1966 nascar charger [Re: CSK] #2755242
03/23/20 09:58 PM
03/23/20 09:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: 1966 nascar charger [Re: topside] #2755256
03/23/20 10:37 PM
03/23/20 10:37 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
the car
Re: 1966 nascar charger [Re: 05dakota] #2755613
03/24/20 09:50 PM
03/24/20 09:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I was a kid at the Daytona 400 race when it first appeared. It was never factory installed for the first race. It was installed at the track, Nascar didn't like it and went to the local Dodge dealer and found out there was a factory part number that was referenced to the spoiler on the Charger pre race, that won. My memory of that spoiler is from seeing the car in the pits, and that it was a big controversy, it was such an oddity at the time for a stock car, it was just a flat piece, and stuck up less then 1/2"?. However I have seen pics since and seems it was higher then that, so I don't know it those pics were from other later races, because it seems more spoiler is always better then less. I don't remember the detail of being one or three pieces, I thought it was just one. I might have some pics from the race I'll look for.
Edit I couldn't find any personal pics that were pertinent, sorry
