Yamaha Inverter Generator #2755120
03/23/20 05:12 PM
03/23/20 05:12 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I have a Yamaha EF3000 ISEB and I'm servicing it for the upcoming camping season. Having trouble crossing the air filter to an affordable one, has anyone done this. The Yamaha number is 7TD-14451-00-00.
11B40
Re: Yamaha Inverter Generator [Re: JonC] #2755130
03/23/20 05:32 PM
03/23/20 05:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Yamaha Inverter Generator [Re: mopars4ever] #2755137
03/23/20 05:40 PM
03/23/20 05:40 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I don't know where that came from, but it looks like this one. https://www.partzilla.com/product/yamaha/7TD-14451-00-00
11B40
Re: Yamaha Inverter Generator [Re: JonC] #2755156
03/23/20 06:16 PM
03/23/20 06:16 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Wix has a pretty good cross reference search function.
If you take the hyphens out of the part number it cross to "This is a valid competitive part number and there is no replacement at this time."
So nothing from Wix. However, if you have the dimensions you can use Wix's lookup tool to search by size and maybe find something that will work.
https://wixfilters.com/Lookup/FilterBySize.aspx
Re: Yamaha Inverter Generator [Re: JonC] #2755164
03/23/20 07:01 PM
03/23/20 07:01 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Yep that's what I've found and that seems to be the cheapest too at $33.00 bucks. Maybe try a local Yamaha dealer for better or best deal??........if they are even open? Or try to find something by original dimension from a place like Stens, McMaster Carr, Granger, etc.,
Re: Yamaha Inverter Generator [Re: A12] #2755170
03/23/20 07:17 PM
03/23/20 07:17 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The one that I showed had the wrong pic but the part number was correct.
Re: Yamaha Inverter Generator [Re: A12] #2755172
03/23/20 07:21 PM
03/23/20 07:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Both of my Yamaha EF2000iSv2 has a foam air filter I believe which make servicing simple.
Re: Yamaha Inverter Generator [Re: mopars4ever] #2755190
03/23/20 07:58 PM
03/23/20 07:58 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Mine has a foam sleeve over the filter. I can salvage that, but need the paper filter.
11B40
Re: Yamaha Inverter Generator [Re: JonC] #2755231
03/23/20 09:42 PM
03/23/20 09:42 PM
Andrewh Online content
Andrewh  Online Content
https://www.yamahapartshouse.com/oemparts/a/yam/5004fa88f8700223a0a0c15f/intake
23 here. if I got it right.
But if it truly looks like that, you might adapt something to use a larger cheaper filter.
