68 A body HP power steering hose where to buy?
#2755008
03/23/20 01:04 PM
03/23/20 01:04 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Looking for a 68 Abody high pressure power steering hose. Can't find one except Rockauto for $160 !!!!! Help !?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 68 A body HP power steering hose where to buy?
[Re: HemiRick]
#2755025
03/23/20 01:29 PM
03/23/20 01:29 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
Do you have the old hose? A NAPA store especially in a rural town can make up hydraulic hoses from your existing hose.
[Re: Sniper]
#2755082
03/23/20 03:49 PM
03/23/20 03:49 PM
Posts: 43,592 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here is the original hose from my 69 383 Dart...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2755087
03/23/20 03:56 PM
03/23/20 03:56 PM
Rhinodart
Rhinotruck
Rhinotruck
The $160 hose looks pretty close to the 383 hose, the ones listed for a 69 383 look nothing like it. Of course you look at the slant six hose and it is the same...
A-Body's RULE!
[Re: Rhinodart]
#2755092
03/23/20 04:05 PM
03/23/20 04:05 PM
HemiRick
Memphis
It's a 273 engine....my hose has fittings/ends on BOTH ends like the lower one in the top pic and upper one in the 2nd pic. It's not the rubber part of the hose that's leaking, but where the end connects to the box there's a drip. Tightening the connection does not stop it. I;ve taken it apart and inspected the metal flare and seat and they look fine.
[Re: Sniper]
#2755108
03/23/20 04:50 PM
03/23/20 04:50 PM
HemiRick
Memphis
Are you saying they have female flare fittings on each end? Yes
[Re: HemiRick]
#2755122
03/23/20 05:16 PM
03/23/20 05:16 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The pump usually has an inverted flare and the box has a male flare. Some A-body boxes have a 90° flare fitting.
[Re: John_Kunkel]
#2755134
03/23/20 05:38 PM
03/23/20 05:38 PM
Rhinodart
Rhinotruck
Rhinotruck
The pump usually has an inverted flare and the box has a male flare. Some A-body boxes have a 90° flare fitting. The big block A-Body has the 90 degree fitting, the small blocks and slants do not. I actually have bought that 90 degree fitting at a parts store out of a Dorman cabinet before. Here is a pic of the hose I had made that is still on my steering box.
A-Body's RULE!
[Re: John_Kunkel]
#2755162
03/23/20 06:51 PM
03/23/20 06:51 PM
HemiRick
Memphis
My car has the 90 degree fitting pictured above....it's dripping off the nut, that tightens the end of the hose at the box......I have removed and inspected both the flare and the fitting....and see no problem....but it's still dripping.....
[Re: Sniper]
#2755200
03/23/20 08:24 PM
03/23/20 08:24 PM
Rhinodart
Rhinotruck
Rhinotruck
The pump end should be a male flare fitting, screws right into the pump. I wonder if the pump is wrong? Or someone added a fitting to it? The pump is the original, I am the second owner and the hose I showed above is the original also. Same pump, sector, and hose I have seen on other 69 big block power steering A-Body's I have owned and judged over the years.
A-Body's RULE!
[Re: Sniper]
#2755253
03/23/20 10:29 PM
03/23/20 10:29 PM
HemiRick
Memphis
Should have pics of both ends of current hose in the morning. Thanks for the help For the most part this a very original unmolested car......
[Re: HemiRick]
#2755499
03/24/20 03:58 PM
03/24/20 03:58 PM
HemiRick
Memphis
I was wrong about the connection at the pump....it's a male.
In the 2nd pic it's dripping off of the fitting.....onto the pump, you can see a little wet spot.
[Re: stumpy]
#2755528
03/24/20 05:11 PM
03/24/20 05:11 PM
HemiRick
Memphis
Thats a good idea! I have a flaring tool.
