Re: Lower control arm coating? [Re: hotairballoonpilot] #2007232
02/07/16 07:56 AM
02/07/16 07:56 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
So, Resto Rick sells both aerosol cosmoline and a paint imitation. Note discussion about coloring.
"Quasimoline Paint
Urethane paint formulated to closely mimic the original cosmoline finish used on Mopar lower control arms. This is an ideal product for those wanting a durable finish that can be wiped clean and not hold dirt like the real thing. Dries to a satin gloss. Darkness & coloring will vary with number of coats applied and color of control arm. Thin with a urethane reducer, no hardener required. Sold in a half pint can for use with a spray gun. One can will easily do two sets of control arms, depending on application thickness. Can also be used to accentuate the coloring of some cast iron parts. $24"
Re: Lower control arm coating? [Re: hotairballoonpilot] #2007662
02/08/16 12:07 AM
02/08/16 12:07 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I used Rick's Quasimoline and liked how it came out. After getting the coverage I wanted, I over-reduced it and hung a couple of runs on the pieces (hanging vertically of course) for good measure.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2008104
02/08/16 07:15 PM
02/08/16 07:15 PM
MO
cdp Offline
cdp  Offline
MO
http://www.schafco.com/cosmoline.asp
couple of good products i've used.
Rust veto, for protecting metal from rusting, and weather shed, cosmoline in a can.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2009324
02/10/16 04:43 PM
02/10/16 04:43 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
On my 70 sport satellite, I cleaned up the lca and then used RPM on them. Let them dry real good, then used real cosmoline on them . . . So even if cosmoline comes off, then the RPM can protect . .
Re: Lower control arm coating? [Re: hotairballoonpilot] #2009906
02/11/16 04:03 PM
02/11/16 04:03 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
I got resto ricks spray can stuff. seemed to work out nice. rough taped a line in them and sprayed hanging up so it has drips and runs in it. Now if it will dry!
Contact Me about AMD Prices
Re: Lower control arm coating? [Re: Stewpar] #2012050
02/14/16 10:19 PM
02/14/16 10:19 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Originally Posted By Stewpar
I used Krylon battery protector and it worked just great!
http://www.ebay.com/itm/Krylon-1307-Battery-Protector-11-oz-Aerosol-New-/371249746007?hash=item5670359057:g:BQcAAOSwBahUz-gi
You Will be happy ..
http://a12mopar.com/yabb/YaBB.pl?num=1232666360
Re: Lower control arm coating? [Re: mopars4ever] #2060023
04/22/16 11:00 PM
04/22/16 11:00 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Originally Posted By mopars4ever
Maybe it`s the pics but Resto Rick`s stuff looks a little to orange? All the NOS ones I have seen were more greenish/darker in color.
It's a match to the original coating. Aside from lighting & photo differences, the number of coats, viscosity of the paint & color of the metal or "metal-look" coating under it will all effect the final color.
Most people tend to put on too much.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2061643
04/25/16 08:54 PM
04/25/16 08:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
NOS upper arm
Re: Lower control arm coating? [Re: hotairballoonpilot] #2061650
04/25/16 09:11 PM
04/25/16 09:11 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Be careful when using NOS parts for correct production line details, they often had different finishes as compared to production.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2111219
07/16/16 05:12 PM
07/16/16 05:12 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
This is an example of the krlyon battery spray.....
if sprayed heavier to make runs you can get a darker/redish end result
Re: Lower control arm coating? [Re: hotairballoonpilot] #2112856
07/18/16 10:54 PM
07/18/16 10:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Looks good I'd be happy with that...
Re: Lower control arm coating? [Re: RJS] #2754882
03/23/20 08:51 AM
03/23/20 08:51 AM
New Jersey
Vinny P Offline
Vinny P  Offline
New Jersey
Hi Ron,
I have a question about the blue and red paint on the LCA pivoting height adjusters tips. The info would be nice additional info to the pictures posted. Or, just give me a call.
Vinny
Superbird B5 4 speed console black buckets
A12 Super Bee Bahama Yellow 4 speed black bench
Re: Lower control arm coating? [Re: Vinny P] #2755978
03/25/20 06:27 PM
03/25/20 06:27 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
here are mine. I bought the paint. from Resto Rick. it works very well. I like the likeness to the cosmoiline, and it's more durable. I may try cosmoiline next time., but want to drive this car.
HEMI,S ARE FOREVER!!!
