hey quicktree #275282
04/02/09 07:06 PM
04/02/09 07:06 PM
Kissimmee Fl.
dusturbd340W5 Offline OP
Kissimmee Fl.
here do these pictures help
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: hey quicktree [Re: dusturbd340W5] #275283
04/02/09 07:06 PM
04/02/09 07:06 PM
Kissimmee Fl.
Kissimmee Fl.
#2
Re: hey quicktree [Re: dusturbd340W5] #275284
04/02/09 07:21 PM
04/02/09 07:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea, thanks Woody. I can't do that with mine. the shock mount is center of my frame rails. the rear is about 4" form the tin on top. I don't see any way install them on this set up. if I had built it I would have changed many things. only possible way I could see to do it would be welding mounts directly to the cast housing and you know how that goes.
