Edelbrock Performer valve springs.
#2752338
03/15/20 09:01 PM
03/15/20 09:01 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
I have edelbrock performer heads with a around 643 lift cam. I need to put new valve springs in it. I shift at 5600 rpm, goes over the line around 6200 rpm. What springs should I use?
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Edelbrock Performer valve springs.
[Re: caper]
#2752346
03/15/20 09:36 PM
03/15/20 09:36 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I think you need more information on the cam to make a recommendation. Did you contact the cam manuf and get their recommendation? Is it solid flat tapper, hyd roller, solid roller? Just fyi, i run a 512 bb stroker with a comp solid flat tappet with .648” lift and 262 @ .050” and i run isky 8005a springs. Pulls hard and fine up to 7000 on my setup. Good spring in my book.
[Re: caper]
#2752606
03/16/20 06:07 PM
03/16/20 06:07 PM
caper
I can't get a hold of Scott. Does anybody know what springs will fit these heads, not sure of spring pressure but it is a custom ground solid flat tappet cam with 643 lift.
[Re: caper]
#2752740
03/17/20 02:20 AM
03/17/20 02:20 AM
Chargerfan68
New York, USA
I can't get a hold of Scott. Does anybody know what springs will fit these heads, not sure of spring pressure but it is a custom ground solid flat tappet cam with 643 lift. You can look at those Isky 8005A springs. I have them on Edelbrock rpm heads for the last 8 years. Like i said, Comp solid flat tappet cam with .648” lift at 260’s @.050 on 110 lsa. Still working awesome. I have a new set waiting to slip in when the time comes. I’ll pull them off, test, and replace if necessary.
