Spark plugs for edelbrock performer heads. #2752602
03/16/20 05:59 PM
03/16/20 05:59 PM
Can , Nova Scotia , Cape Breto...
caper Offline OP
caper  Offline OP
What spark plugs for edelbrock performer heads. 10.7:1 compression, TTI headers, 654 hp. street/strip. Thanks.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Spark plugs for edelbrock performer heads. [Re: caper] #2752622
03/16/20 07:09 PM
03/16/20 07:09 PM
AndyF Offline
AndyF  Offline
I use NGK 6987 for all my pump gas builds. It is an OEM plug so the price is reasonable. Should be fairly easy to find.
Re: Spark plugs for edelbrock performer heads. [Re: AndyF] #2752624
03/16/20 07:15 PM
03/16/20 07:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Been a few years since I had Eddys, but don't they use the same plug architecture (size/thread/reach) as 340 & Hemi ?
Re: Spark plugs for edelbrock performer heads. [Re: topside] #2752637
03/16/20 07:41 PM
03/16/20 07:41 PM
caper Offline OP
caper  Offline OP
Not sure on that. I am not around my car, but I thing I have a NGK racing plug with heat range around 7.
Re: Spark plugs for edelbrock performer heads. [Re: caper] #2752647
03/16/20 08:05 PM
03/16/20 08:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the edelbrock heads use a 5/8" hex, 3/4" reach plug. I've been using autolite 3923, 3924, or 3926; depending on what i'm doing. i'm sure an NGK equivalent would work well.
Re: Spark plugs for edelbrock performer heads. [Re: caper] #2752654
03/16/20 08:35 PM
03/16/20 08:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran 8's at 12.1 comp and it ran well then I tried 7's and runs even better so I'd say a #6 will be real close at your comp.....
Re: Spark plugs for edelbrock performer heads. [Re: caper] #2752666
03/16/20 09:05 PM
03/16/20 09:05 PM
Champion RC9YC, Auotlite 3923 or 3924 up
I've no idea on current NGK #s shruggy
Re: Spark plugs for edelbrock performer heads. [Re: lewtot184] #2752688
03/16/20 10:06 PM
03/16/20 10:06 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Being Alumium heads do you all think you should start with a standard heat of go colder? I was told to run a 5/8 version of the RN12YC but I want Iridum so I went for Denso IQ16TT's that are in the heat range of 12. They have a colder IQ20TT too that is a 9 to10 heat range
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Spark plugs for edelbrock performer heads. [Re: Dave_J] #2752870
03/17/20 03:53 PM
03/17/20 03:53 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
The reason I ask is I have never run aluminum heads on anything except my 2.2's. Someone told me that if the Iron head required a RN12YC that the alumumn would wick too much heat out of that plug so 1 or 2 steps hotter is needed.
1984 Dodge Shelby 2.2 10:1 CR was RN12YC. Mine was a 0.040 over true 11.2:1 CR and I found a RN9YC worked best.
1984 Dodge Rampage 2.2 8.5:1 CR was RN14YC
65 Formula S Cuda
