Transmission Bands
#275197
04/02/09 03:33 PM
04/02/09 03:33 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
HI, Took my 904 apart (off a 5th ave), and yes it has 5 disc clutch, but I am puzzled about the very wide low-reverse band. Does this make any sens ? I thought the kick down band was absorbing the biggest schock and therefore should be wider ? it is just as wide as the 904 from my '67 with a 273...I tought it should heve been the 1.6 inch wide one at least ? ![](http://i619.photobucket.com/albums/tt272/wedgeman67/DSC00444.jpg)
Re: Transmission Bands
[Re: Wedgeman]
#275198
04/02/09 06:51 PM
04/02/09 06:51 PM
Posts: 26,011 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Starting in '68 V8 904's (904-LA) got the double-wrap rear band and the /6 still had the narrow band.
[Re: Wedgeman]
#275200
04/02/09 09:39 PM
04/02/09 09:39 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Another tip for you, look at the kickdown band for a number on the side, use the one with the highest number.
