P/S Pump Cap #2751260
03/12/20 01:21 PM
03/12/20 01:21 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
Looking for a filler cap for the pump on the left below. The filler neck has two bumps on the outside so the cap has twist slots rather than ears.
What is the factory designation of this pump i.e. 1.02, 1.06, etc? Most sources list them by maker i.e. Federal, TRW, etc.
Re: P/S Pump Cap [Re: John_Kunkel] #2751293
03/12/20 02:51 PM
03/12/20 02:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If memory serves, those used a stamped/drawn cap that was knurled, right ?
Had a tiny vent hole in the top ?
I think Dad's '66 Sport Fury had that, or maybe it was the '64 Savoy.
Re: P/S Pump Cap [Re: topside] #2751315
03/12/20 03:38 PM
03/12/20 03:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
My 64 300 had one of those style caps.
I believe it's part number 2127284.
https://www.ebay.com/p/1258201577
Re: P/S Pump Cap [Re: Sniper] #2751361
03/12/20 06:33 PM
03/12/20 06:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup, and plated like that, not painted, is what I recall.
Re: P/S Pump Cap [Re: topside] #2751454
03/13/20 06:48 AM
03/13/20 06:48 AM
VA
dragon slayer Offline
VA
You need to look at shaft to determine specific pump size along with can dia and possibly the casting markers on pump if original type. The Early pumps were Thompson. A .96L with solid shaft 4 5/8" dia can, and the 1.20L with Hex hole shaft and 5 1/8" dia can.
