Page 3 of 5 1 2 3 4 5
Re: 420 going on the dyno next couple days [Re: Brian Hafliger] #2668568
06/21/19 11:38 PM
06/21/19 11:38 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Thanks for all the input guys all good stuff much appreciated.
Re: 420 going on the dyno next couple days [Re: biff426] #2668576
06/21/19 11:55 PM
06/21/19 11:55 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
It just hit me. We talked about those behives on those heads before you even bought them, correct?
Put a .010 pushrod in the motor
Re: 420 going on the dyno next couple days [Re: sixpackgut] #2668579
06/22/19 12:08 AM
06/22/19 12:08 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
We did talk about it. I was nervous then and I talked myself into keeping the springs on there. I really feel if I can get it to carry power to 75-7600 it would make 780ish. What part number lifter do you use?
Re: 420 going on the dyno next couple days [Re: biff426] #2668592
06/22/19 06:22 AM
06/22/19 06:22 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
In current motor I have been running for years has been stock lifter. The other set for new engine and the lifter Steff was running is the hylift 2335s lifter
Re: 420 going on the dyno next couple days [Re: sixpackgut] #2668660
06/22/19 10:43 AM
06/22/19 10:43 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Anyone try shorter tip valves and lash caps with stock rockers?
Re: 420 going on the dyno next couple days [Re: fbs63] #2668666
06/22/19 11:01 AM
06/22/19 11:01 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Throw that sucker in this car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 420 going on the dyno next couple days [Re: pittsburghracer] #2668794
06/22/19 06:48 PM
06/22/19 06:48 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Whos car is that? Always wanted one. They look great with big tire too
Re: 420 going on the dyno next couple days [Re: sixpackgut] #2668796
06/22/19 07:02 PM
06/22/19 07:02 PM
PA.
"Little"John
"Little"John
PA.
Brad watt had a picture of it and a post looking for this car for a Friend. A for sale ad came up shortly after that. I think it’s in Ohio
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 420 going on the dyno next couple days [Re: pittsburghracer] #2668797
06/22/19 07:05 PM
06/22/19 07:05 PM
PA.
"Little"John
"Little"John
PA.
I think an 8 second Gen 3 would look pretty cool planted between the frame rails
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 420 going on the dyno next couple days [Re: pittsburghracer] #2668798
06/22/19 07:16 PM
06/22/19 07:16 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
If I had you money I would buy it
Re: 420 going on the dyno next couple days [Re: sixpackgut] #2668801
06/22/19 07:27 PM
06/22/19 07:27 PM
PA.
"Little"John
"Little"John
PA.
If I had your money I would build a Gen 3.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 420 going on the dyno next couple days [Re: pittsburghracer] #2668839
06/22/19 09:49 PM
06/22/19 09:49 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Lol touche
Re: 420 going on the dyno next couple days [Re: biff426] #2671328
06/28/19 09:46 PM
06/28/19 09:46 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
SO made a couple hits with the 850 dyno carb and timing from 20-26 degrees it liked 22 made 748HP.@7300. Putting the bigger carb and spacers on it and going to play with jetting should be worth some HP. ALso the headers we had to use are 13/4 and the ones going in the car are 2" not sure what if anything that will do. Can't get the 2" to fit on the dyno without reinventing the wheel.
I was within 8hp,,,,,,,,Nice little beast there.
Re: 420 going on the dyno next couple days [Re: Dragula] #2674784
07/06/19 11:17 AM
07/06/19 11:17 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Any Updates?
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: 420 going on the dyno next couple days [Re: Ray408G3Hemi] #2674866
07/06/19 03:00 PM
07/06/19 03:00 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Making a lifter and spring change. updating to Manton shafts and putting a vacuum pump on it. Everything is ordered just waiting for some parts to show up.
Re: 420 going on the dyno next couple days [Re: biff426] #2750934
03/11/20 09:49 AM
03/11/20 09:49 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
All the updates are done its back on the dyno hopefully we can make in the 775hp range
updates
Short travel lifters
Manton Shafts
Vac pump
Spring change to PSI 1516
lash caps
putting the 2 inch header on it
We had some valve float issues on the last pulls we made before the updates
Re: 420 going on the dyno next couple days [Re: biff426] #2750953
03/11/20 10:57 AM
03/11/20 10:57 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Hows the rocker geometry with the lash caps?
Re: 420 going on the dyno updated 3-11-20 [Re: biff426] #2750994
03/11/20 01:03 PM
03/11/20 01:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Am I reading this all right that you made 750ish HP with stock rockers and lifters?
Re: 420 going on the dyno next couple days [Re: fbs63] #2751000
03/11/20 01:24 PM
03/11/20 01:24 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
The geometry is pretty good I wouldn't say great as the valve was already a little tall but it gives the rocker more area on the valve.
Yes we made 748 with the stock rockers and hellcat lifters from mopar the lifters were not happy in the upper rpm range 6500-up and I can't really blame the lifter I think the spring had a lot to do with it.
Re: 420 going on the dyno next couple days [Re: biff426] #2751548
03/13/20 01:27 PM
03/13/20 01:27 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Made a couple light pulls but the puke tank is getting a ton of oil through the vacuum pump. I have the Ritter intake and have the pickup for the vacuum pump coming out of the oil fill. The valve covers are not very friendly for a fitting. Who has ever used a vac pump on one of these and where do you put the fitting. We leaked the enegine and it leaks 4% cold so I don't think it's that the engine has blowby. This thing is pushing a bunch of oil in the higher RPMs.
