440 Radiator Bracket
#2750764
03/10/20 02:32 PM
03/10/20 02:32 PM
Posts: 1,534 Florida
CHRGR69
Always something. The curved support bracket on the top of the rad (1 on each side) separated from the rad. Don't have welding access and not taking it out. JB weld?
Grandma always said I had "hands of gold"!
Re: 440 Radiator Bracket
[Re: CHRGR69]
#2750770
03/10/20 02:55 PM
03/10/20 02:55 PM
Posts: 3,529 Lansing, MI
70gtx440dana
Lansing, MI
Those brackets are soldered to tanks. You may be able to solder without removing if you are careful. You will have to drain coolant.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: CHRGR69]
#2750841
03/10/20 10:01 PM
03/10/20 10:01 PM
Posts: 30,496 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Always something. The curved support bracket on the top of the rad (1 on each side) separated from the rad. Don't have welding access and not taking it out. JB weld? High temp silicone will be your friend !
[Re: dOc …]
#2750902
03/11/20 08:06 AM
03/11/20 08:06 AM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Always something. The curved support bracket on the top of the rad (1 on each side) separated from the rad. Don't have welding access and not taking it out. JB weld? High temp silicone will be your friend ! Fix it right. Simple and inexpensive. Pull the radiator, prep and re-solder the brackets. A propane torch will work. If you can not solder it at least pull it and bring it to a shop that can. Forget the JB, silicone and all the other hack methods.
[Re: NITROUSN]
#2750906
03/11/20 08:13 AM
03/11/20 08:13 AM
dOc …
Florida STAYcation
Always something. The curved support bracket on the top of the rad (1 on each side) separated from the rad. Don't have welding access and not taking it out. JB weld? High temp silicone will be your friend ! Fix it right. Simple and inexpensive. Pull the radiator, prep and re-solder the brackets. A propane torch will work. If you can not solder it at least pull it and bring it to a shop that can. Forget the JB, silicone and all the other hack methods. Hack method ? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) No reason being a GRUMP here ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Jsta because it hasn’t gotten ABOVE ZERO way up in northern Meeeeeechigan in the last SIX MONTHS ! ![xmaseek xmaseek](/ubbthreads/images/graemlins/custom/xmaseek.gif)
[Re: lewtot184]
#2750930
03/11/20 09:38 AM
03/11/20 09:38 AM
dOc …
Florida STAYcation
re-soldering the bracket is the correct way to fix the problem. any kind of epoxy/silicone will really screw you up if you try to do a correct repair later on. Siliconé will screw it up ? A quick hit with a wire brush gets rid of any silicone at a later time
[Re: dOc …]
#2750949
03/11/20 10:46 AM
03/11/20 10:46 AM
Posts: 3,916 usa
lewtot184
usa
re-soldering the bracket is the correct way to fix the problem. any kind of epoxy/silicone will really screw you up if you try to do a correct repair later on. Siliconé will screw it up ? A quick hit with a wire brush gets rid of any silicone at a later time if that's what you believe then it tells me you have no experience soldering metals together.
[Re: lewtot184]
#2750968
03/11/20 11:46 AM
03/11/20 11:46 AM
Posts: 19,654 north of coder
moparx
re-soldering the bracket is the correct way to fix the problem. any kind of epoxy/silicone will really screw you up if you try to do a correct repair later on. Siliconé will screw it up ? A quick hit with a wire brush gets rid of any silicone at a later time if that's what you believe then it tells me you have no experience soldering metals together. wait until you try to solder the bracket to the tank with the left over silicon [or jb weld, or whatever] that migrated under the bracket you can't clean off. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
