Windshield moulding #2750213
03/08/20 06:07 PM
03/08/20 06:07 PM
Cincinnati Ohio USA
Moeggenpar Offline OP
Cincinnati Ohio USA
I have a 68ā€™ Charger. Is the windshield trim moulding the same on all 68 to 70 B bodies? Thanks
Re: Windshield moulding [Re: Moeggenpar] #2750217
03/08/20 06:11 PM
03/08/20 06:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes,
its the sides and uppers that differ between body styles
Re: Windshield moulding [Re: gtx6970] #2750244
03/08/20 07:41 PM
03/08/20 07:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by gtx6970
Yes,
GTX, your answer is confusing to me at least frown
Which body styles are the same and or or different shruggy beer
Re: Windshield moulding [Re: gtx6970] #2750261
03/08/20 08:56 PM
03/08/20 08:56 PM
Cincinnati Ohio USA
Cincinnati Ohio USA
Iā€™m a little confused too. So the top and sides differ on A and C bodies but the trim is the same all the way around on 68 to 70 B bodies? Thanks again
Re: Windshield moulding [Re: Moeggenpar] #2750267
03/08/20 09:07 PM
03/08/20 09:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I believe all the 2-door '68-'70 Bs use the same windshield moldings.
Can't speak for convertibles (maybe the lower is same).
I hear the 4-door windshields are tall, but don't know for certain.
So maybe the top & bottom on 4-doors is same, sides may be taller.
Someone must have a parts manual, and can advise accordingly...
Re: Windshield moulding [Re: topside] #2750284
03/08/20 09:36 PM
03/08/20 09:36 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The lower mldg is the same " I think" from 1966 to 70 on B bodies regardless if vert, sedan / wagon or 2 door hardtop
its the sides I know for sure are different between 2 door hardtops versus sedans and wagons, 2 door hardtops are shorter , ( found it out the hard way )
The top mldg Im not 100% sure if its different between them or not
