71 Barracuda radios, what are you using #2749785
03/07/20 10:31 AM
03/07/20 10:31 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I'm putting the dash together for our 71 Barracuda and I'm ready to order a radio. Would like something modern, Bluetooth, Sirrus Xm, USB compatible but looks factory. I'm finding very little to choose from. I don't want to cut the dash and may build a custom console if I have to mount a modern sound system. What have you folks found that works? Pics if possible.
Re: 71 Barracuda radios, what are you using [Re: AeroMonte] #2749800
03/07/20 11:38 AM
03/07/20 11:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Had one built using an original E body core at Turnswitch.com
Re: 71 Barracuda radios, what are you using [Re: gtx6970] #2749982
03/07/20 09:57 PM
03/07/20 09:57 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have this radio in my car with a factory look. It has bluetooth, digital tuner, higher output, amp-preouts and aux input.
It's expensive but I feel it's worth it. The radio looks right, it's all new and does what it's supposed to. I have zero desire to cut the dash and/or have any dual/remote mounted radio contraptions. I don't like Sirius XM and I just use my phone instead of a USB stick.
http://www.vintageautoradio.com/ind...&option=com_virtuemart&Itemid=67
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 71 Barracuda radios, what are you using [Re: GoodysGotaCuda] #2750046
03/08/20 08:53 AM
03/08/20 08:53 AM
S.E. Missouri
S.E. Missouri
Thanks, Goody. I'll look into that one.
Re: 71 Barracuda radios, what are you using [Re: AeroMonte] #2750068
03/08/20 10:31 AM
03/08/20 10:31 AM
None
71rm23 Offline
71rm23  Offline
None
Took my original radio for my '71 and sent it to Turnswitch on the advice of Ward's Classic Radio. They gutted the inside and put all modern electronics of today's radio in it and with jacks to plug my phone in it. I went this route because I have a cassette player that came with my car and wanted it to be able to plug into it as well. I also bought new speakers for the rear and the front has a dual speaker set-up and they both fit in the original hole with no modification to the car. Sorry, I don't have pictures right at the moment.
Re: 71 Barracuda radios, what are you using [Re: 71rm23] #2750223
03/08/20 06:28 PM
03/08/20 06:28 PM
S.E. Missouri
S.E. Missouri
I have new rear speakers and a sub mounted already. I ordered a dual speaker for the dash from Classic. I had ordered a radio from them last June but it never arrived and the part number is no longer good. Retro Radio has nothing. I thought about going with a radio delete plate and mounting something in a custom console. Our car is a resto mod and not a restoration.
