Re: Hemi 4spd Charger 500 [Re: hemi70se] #2749373
03/05/20 07:05 PM
03/05/20 07:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by hemi70se
A power drum brake HEMI would have a painted master cylinder too. The manual brake ones were left natural. I see they painted the engine components all separated and then bolted them together with natural bolts... oopps!
Something interesting if you look is that it has a rubber plug for the hole where the headlight vacuum lines would have been. I would think the factory would have just not bored the hole out on "500" models, just the same way they do on the tach wire hole. Never seen a plug before. Makes you wonder about it being a normal charger firewall and the bodyman didn't catch the extra hole he need to weld up.
Most Charger 500s the hoses were just cut off at the firewall and left there during the conversion
Re: Hemi 4spd Charger 500 [Re: 69x] #2749374
03/05/20 07:07 PM
03/05/20 07:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by 69x
Originally Posted by 6bblgt
drool
a $65 remedy scope & don't paint it "black" twocents
Would this ebay master cylinder be correct for a 69 GTX ? Someone I know said he could rebuild mine for $240, seems like a lot, maybe I should buy the one on ebay. the lid on mine has a silver finish, do they change in color over time ?, Thanks
yes,
Strap and bolt should be a dark phosphate color
silver cap is/was aftermkt
Re: Hemi 4spd Charger 500 [Re: gtx6970] #2749411
03/05/20 08:56 PM
03/05/20 08:56 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Wow, it didn't seem that Mick was looking to have the car picked apart but it happened anyway.
Re: Hemi 4spd Charger 500 [Re: Jjs72D] #2749482
03/06/20 02:03 AM
03/06/20 02:03 AM
California
mickm Offline OP
mickm  Offline OP
California
That's ok, I more or less expected it!
But just wanted to put it up for people to see. it is an amazing car!
Re: Hemi Charger 500 [Re: Jjs72D] #2749483
03/06/20 02:05 AM
03/06/20 02:05 AM
California
mickm Offline OP
mickm  Offline OP
California
That is a great looking car. Do you think he will have it at the Spring Fling car show this April ?
I don't know who the owner is. Has a bunch of cars though. Had a 69 Hemi Road Runner in there before this one being restored. No idea if it will be at the fling or not.
Re: Hemi 4spd Charger 500 [Re: mickm] #2749533
03/06/20 11:44 AM
03/06/20 11:44 AM
Bloomington, IN
HoosierTA Offline
HoosierTA  Offline
Bloomington, IN
Gorgeous! Another great one resurrected.
'70 Challenger R/T 383
'16 Hemi Durango SSV (work vehicle)
'15 Ram Police SSV
Re: Hemi 4spd Charger 500 [Re: HoosierTA] #2749808
03/07/20 12:08 PM
03/07/20 12:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think this is a friend of mine's former car. He sold it when he became ill and luckily recovered. It's a great car.
Re: Hemi 4spd Charger 500 [Re: Morty426] #2749821
03/07/20 12:27 PM
03/07/20 12:27 PM
central il.
second 70 Offline
second 70  Offline
central il.
Even as a kid I thought how could they have ruined the look of one of the coolest cars ever with that front end. I was young and just thought the guy was too cheap to buy the hideaway headlights. Lol I now know it was modified to try and make it not slide down the track at Daytona but it still had trouble and that's when they added the nose cone and wing and made the car cool again.
Re: Hemi 4spd Charger 500 [Re: second 70] #2749828
03/07/20 12:36 PM
03/07/20 12:36 PM
The Historic Hudson Valley
MONC Offline
MONC  Offline
I like the non-console 4 speed .
Don't think I'd want manual drum brakes with all that weight and power. I'd upgrade to factory power discs in front.
Mopar
Or
No
Car
Re: Hemi 4spd Charger 500 [Re: Jjs72D] #2749855
03/07/20 01:20 PM
03/07/20 01:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My comment was never meant to pick it apart.
Thing is, a lot of people use this threads as reference. and NO ONE learns if someone doesnt point out flaws / errors
Re: Hemi 4spd Charger 500 [Re: gtx6970] #2749885
03/07/20 02:36 PM
03/07/20 02:36 PM
MA
steve70 Offline
steve70  Offline
MA
iagree Some of the items are an easy fix so why not learn what's correct?
1970 Challenger T/A 4 speed
Re: Hemi 4spd Charger 500 [Re: mickm] #2750290
03/08/20 09:53 PM
03/08/20 09:53 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
are the washer dia on front pad in front of rubber hood adjuster the same as fender bolts?not talking about this car but on all 68-70 B-bodies.
Re: Hemi 4spd Charger 500 [Re: sixbbl 69] #2751545
03/13/20 01:12 PM
03/13/20 01:12 PM
Germany
fc7_plumcrazy Offline
Germany
thanks for sharing
Carsten
