Re: top end oiling...full roller
[Re: limelight440]
#274942
04/02/09 12:42 PM
04/02/09 12:42 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
There will not be puddles of oil on top of the rockers like the old bathtub stamped rockers but you should have a decent amount of oil around the areas that do not drain back well. Like on the corners on the heads. You will want good oil flow up there.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: limelight440]
#274944
04/02/09 12:54 PM
04/02/09 12:54 PM
Jacob Pitt
Mansfield, Tx
Keep an eye on it, as long as your getting oil up there you should be fine. The roller rockers do not need splash oiling as they are designed to oil the shaft and usually have oiling slots for the tips so the oil stays under control better.
