What is this tool? #2749106
03/04/20 11:20 PM
03/04/20 11:20 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
I found it down in my barn earlier today buried under some hay,
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What is this tool? [Re: BloFish] #2749107
03/04/20 11:21 PM
03/04/20 11:21 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Let me try this again
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What is this tool? [Re: BloFish] #2749108
03/04/20 11:22 PM
03/04/20 11:22 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Ring groove cleaner.
Sorry it took me so long to answer..... grin
Re: What is this tool? [Re: BloFish] #2749109
03/04/20 11:23 PM
03/04/20 11:23 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Here
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What is this tool? [Re: BloFish] #2749110
03/04/20 11:23 PM
03/04/20 11:23 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Thanks John
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What is this tool? [Re: John Brown] #2749128
03/05/20 12:32 AM
03/05/20 12:32 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yep, I have one just like it, belonged to my Dad.
Re: What is this tool? [Re: justinp61] #2749131
03/05/20 12:45 AM
03/05/20 12:45 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
hOpEfUlLy yur pistons never get that garbaged up to require the usage of that tool .., eek
Re: What is this tool? [Re: dOoC] #2749158
03/05/20 06:38 AM
03/05/20 06:38 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I have one too , ring groove cleaner.
Re: What is this tool? [Re: hemirdrnnr] #2749159
03/05/20 07:10 AM
03/05/20 07:10 AM
Garage
N
NicBuc Offline
NicBuc  Offline
N
Garage
I know, I know, I know...it's a ring groove cleaner.
Re: What is this tool? [Re: NicBuc] #2749283
03/05/20 02:07 PM
03/05/20 02:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Ring groove destroyer more like it if you aren't careful. They will remove aluminum as well.
Re: What is this tool? [Re: CMcAllister] #2749285
03/05/20 02:21 PM
03/05/20 02:21 PM
Many of us didn't know about the carbon build up behind the rings on used high mileage motors and the need to remove that carbon before replacing the rings.
You do need to be very careful on setting the depth so you don't scrape or remove any aluminum from the pistons tsk
I use to soak the pistons in hot soapy water for a while to help soften the carbon and then use a broken ring to scrape it out after damaging several pistons due to not setting the depth correctly realcrazy
Murphy lurks and loves messing with us hot rodders whiney grin
Re: What is this tool? [Re: Cab_Burge] #2749308
03/05/20 03:47 PM
03/05/20 03:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, that's how we learned in the Doctor of Motors class.
Re: What is this tool? [Re: CMcAllister] #2749314
03/05/20 04:11 PM
03/05/20 04:11 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
https://www.orisonmarketing.com/pistonkleen.html
Caterpillar Inc. patent
https://patents.google.com/patent/US20100115721A1/en
Sample quote
Known carbon cleaning agents for use on disassembled engine components include
ULTRA ONE™ (sodium metasilicate, surfactants, water),
GM Goodwrench ® TOP ENGINE CLEANER (2-butoxyethanol, naphtha, 4-methyl-2-pentanol, 9-octadecendic acid) and
PRO SERIES SIMPLE GREEN® MAX AUTOMOTIVE CLEANER & DEGREASER (2-butoxyethanol, water).
Other engine cleaning agents include
acetone,
benzyl alcohol,
propylene glycol,
ethylene glycol,
Polyol esters,
n-methylpyrrolidone,
nonylphenols
and others.
Steam cleaning and cleaning with dry ice (CO2) are also known.
End quote
Re: What is this tool? [Re: 360view] #2749428
03/05/20 09:35 PM
03/05/20 09:35 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Sample quote
GM Goodwrench ® TOP ENGINE CLEANER (2-butoxyethanol, naphtha, 4-methyl-2-pentanol, 9-octadecendic acid) and,
acetone,
benzyl alcohol,
propylene glycol,
ethylene glycol,
Polyol esters,
nonylphenols
and others.
End quote
Sodium Metasilicate was the main active ingredient in Westley's Bleche-Wite from years past. Same chemical was used in many other WW cleaners. It was what caused the hard to breathe sensation when you sprayed it on a tire. This chemical IS NOT the same as Sodium Silicate. Sodium Silicate is used as a skin tightener in cosmetics. Sodium Metasilicate would cause skin burns when applied to the skin. Good thing pistons are more sturdy than skin.
Re: What is this tool? [Re: John Brown] #2749471
03/06/20 12:12 AM
03/06/20 12:12 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i just soaked the pistons in carb cleaner
my ladder of success is missing some rungs
Re: What is this tool? [Re: rhad] #2749520
03/06/20 10:09 AM
03/06/20 10:09 AM
USA
3
360view Offline
360view  Offline
3
USA
Around 1998 I soaked 8 used 1994 Magnum 5.9V8 used pistons in various chemicals in Folgers Coffee metal cans and the Liqui Moly “Ventril Sauber” from BMW dealerships ( means valve cleaner in German) did best,
better than Chevron Techron, Seafoam, ATF+2, Mobil One 10W-30, acetone
Re: What is this tool? [Re: 360view] #2749522
03/06/20 10:14 AM
03/06/20 10:14 AM
USA
3
360view Offline
360view  Offline
3
USA
