What is this tool?
#2749106
03/04/20 11:20 PM
03/04/20 11:20 PM
Posts: 16,538 On the run…
BloFish
On the run…
I found it down in my barn earlier today buried under some hay,
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: What is this tool?
[Re: BloFish]
#2749108
03/04/20 11:22 PM
03/04/20 11:22 PM
Posts: 1,848 South Bend
John Brown
South Bend
Ring groove cleaner. Sorry it took me so long to answer.....
[Re: John Brown]
#2749128
03/05/20 12:32 AM
03/05/20 12:32 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Ring groove cleaner. Sorry it took me so long to answer..... Yep, I have one just like it, belonged to my Dad.
[Re: NicBuc]
#2749283
03/05/20 02:07 PM
03/05/20 02:07 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Ring groove destroyer more like it if you aren't careful. They will remove aluminum as well.
[Re: CMcAllister]
#2749285
03/05/20 02:21 PM
03/05/20 02:21 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
Many of us didn't know about the carbon build up behind the rings on used high mileage motors and the need to remove that carbon before replacing the rings. You do need to be very careful on setting the depth so you don't scrape or remove any aluminum from the pistons I use to soak the pistons in hot soapy water for a while to help soften the carbon and then use a broken ring to scrape it out after damaging several pistons due to not setting the depth correctly Murphy lurks and loves messing with us hot rodders
[Re: Cab_Burge]
#2749308
03/05/20 03:47 PM
03/05/20 03:47 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
use a broken ring to scrape it out Yep, that's how we learned in the Doctor of Motors class.
[Re: CMcAllister]
#2749314
03/05/20 04:11 PM
03/05/20 04:11 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
https://www.orisonmarketing.com/pistonkleen.htmlCaterpillar Inc. patent https://patents.google.com/patent/US20100115721A1/enSample quote ] Known carbon cleaning agents for use on disassembled engine components include ULTRA ONE™ (sodium metasilicate, surfactants, water), GM Goodwrench ® TOP ENGINE CLEANER (2-butoxyethanol, naphtha, 4-methyl-2-pentanol, 9-octadecendic acid) and PRO SERIES SIMPLE GREEN® MAX AUTOMOTIVE CLEANER & DEGREASER (2-butoxyethanol, water). Other engine cleaning agents include acetone, benzyl alcohol, propylene glycol, ethylene glycol, Polyol esters, n-methylpyrrolidone, nonylphenols and others. Steam cleaning and cleaning with dry ice (CO2) are also known. End quote
[Re: 360view]
#2749428
03/05/20 09:35 PM
03/05/20 09:35 PM
John Brown
South Bend
https://www.orisonmarketing.com/pistonkleen.htmlCaterpillar Inc. patent https://patents.google.com/patent/US20100115721A1/enSample quote Known carbon cleaning agents for use on disassembled engine components include ULTRA ONE™ (sodium metasilicate, surfactants, water), GM Goodwrench ® TOP ENGINE CLEANER (2-butoxyethanol, naphtha, 4-methyl-2-pentanol, 9-octadecendic acid) and, PRO SERIES SIMPLE GREEN® MAX AUTOMOTIVE CLEANER & DEGREASER (2-butoxyethanol, water) Other engine cleaning agents include acetone, benzyl alcohol, propylene glycol, ethylene glycol, Polyol esters, n-methylpyrrolidone, nonylphenols and others. Steam cleaning and cleaning with dry ice (CO2) are also known. End quote Sodium Metasilicate was the main active ingredient in Westley's Bleche-Wite from years past. Same chemical was used in many other WW cleaners. It was what caused the hard to breathe sensation when you sprayed it on a tire. This chemical IS NOT the same as Sodium Silicate. Sodium Silicate is used as a skin tightener in cosmetics. Sodium Metasilicate would cause skin burns when applied to the skin. Good thing pistons are more sturdy than skin.
[Re: John Brown]
#2749471
03/06/20 12:12 AM
03/06/20 12:12 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i just soaked the pistons in carb cleaner
my ladder of success is missing some rungs
[Re: rhad]
#2749520
03/06/20 10:09 AM
03/06/20 10:09 AM
Posts: 8,162 USA
360view
USA
Around 1998 I soaked 8 used 1994 Magnum 5.9V8 used pistons in various chemicals in Folgers Coffee metal cans and the Liqui Moly “Ventril Sauber” from BMW dealerships ( means valve cleaner in German) did best, better than Chevron Techron, Seafoam, ATF+2, Mobil One 10W-30, acetone
[Re: 360view]
#2749522
03/06/20 10:14 AM
03/06/20 10:14 AM
Posts: 8,162 USA
360view
USA
